Regarding the addition of new parameter in ValidateCounterparties,Extract & ValidateInstruments API's in C#
We are using refinitiv datascope and recently,we have moved from old reuters.com url to refinitiv.com url and our expectations are just changing the URL should be enough. But we do see that existing API's which we used got changed and below API's needed an extra parameter EjvServerHeader.
The API’s within the ExtractionServiceClient are changed as shown below :-
  1. ValidateInstruments :-
    ValidateInstruments(ref CredentialsHeader CredentialsHeader, EjvServerHeader EjvServerHeader, InstrumentValidationRequest request, out InstrumentValidationResponse ValidateInstrumentsResult)
  2. Extract
    Extract(ref CredentialsHeader CredentialsHeader, EjvServerHeader EjvServerHeader, ExtractionRequest request, out ExtractionResponse ExtractResult)
  3. ValidateCounterparties
    ValidateCounterparties(ref CredentialsHeader CredentialsHeader, EjvServerHeader EjvServerHeader, CounterpartyValidationRequest request, out CounterpartyValidationResponse ValidateCounterpartiesResult)
We want to know the purpose of the extra parameter and what is the purpose it serves, currently, I gave an empty structure and it's working fine. But I want to know it's purpose
Code is implemented in C#
It is about SOAP API not rest API, but anyway thank you for moving it into concerned group
23k 22 9 14
Hello @pkruthiventi,
Thanks.
We have verified your inquiry with the product team, and they confirm as follows:
"The header EjvServerHeader is not a new and was added in 2017.
This header was added for special cases, and should not be applicable for the majority of clients.
If they never used that before they can ignore it, in this case API will use the load balancer by default.".
Therefore, for your implementation this header is safe to disregard,
Hope this information helps.
23k 22 9 14
I think you are referring to Refinitiv Tick History - Mandatory Technical Migrations.
If you follow the link to PCN (Product Change Notification) to My Refinitv, please find both PCN and Mandatory Migration User Guide document, with a section on DSS SOAP migration.
From my reviewing the required changes for DSS SOAP, I do not see these in the required to migrate sections.
This is why I would suggest, waiting till DSS 15.0 is released (which is imminent, I was told that targeted date is June 5th) and consequently verifying, via complete set of released DSS 15.0 documentation, if the change you discuss is required in order to request the same content that you are currently requesting, or it rather covers additional functionality being introduced in 15.0.
Hope this helps
i am talking about refinitiv data scope for reference data not realtime data. Let me know if i can get a developer document and let me know where to search the document in the community forum.
We are using SOAP API not rest API, we are calling above functions to performs the required validation functions etc., in C#. We need to look into soap api migration materials and I looked into it and I don't see any change. I already followed the suggestions given in the document and updated everything through WSDL but the function definition got changed which we are using and I am getting compilation issues. It shows that a new parameter is added called EjvServerHeader and I am currently passing an empty structure to make it pass. Let me know whether my explanation is enough.
