Time format in FID 3855 QUOTIM_MS
FID 3855.pngHi Team,
Would you share your insights why real time data feed send the value on FID 3855 QUOTIM_MS in integer format instead of hh:mm:ss:000 format?
and how to programmatically convert this to a timestamp, and to officially sign off that it is IN MILLISECONDS time format?
Thanks & Regards,
Xia
elektronrefinitiv-realtimeelektron-sdkrrt
@XIA LIU
The values in those fields (with suffix "_MS" and UINT64) represent timestamps in milliseconds within a day. You can use the below logic to convert milliseconds within a day to time.
int msec = time_ms%1000; int seconds = (((int)(time_ms/1000)) % 60); int minutes = (((int)(time_ms/60000)) % 60); int hours = (((int)(time_ms/3600000)) % 24);
