DataScopeSelect mandatory name changes - verification
Is there a way to verify that we have made all the necessary changes to adapt to your TR -> Refinitiv name changes?
For example, perhaps if we're accessing only refinitiv.com urls then only the new field names will work?
It would be unfortunate to have no method of comprehensively testing this, until the "old" functionality is turned off.
Hi @davet1,
The old fieldnames and namespaces will not work with the new URL's. So as long as you can ensure that your application is pointing to new refinitiv.com domain, any legacy artifacts in your application will generate an error.
Great news, thank you.
