Error in http_statuses[[as.character(status)]] : subscript out of bounds, when creating connection using DatastreamDSWS2R
When I am running the following using RStudio, I get the following error message. Can anyone help to fix the issue?
library('DatastreamDSWS2R')
options(Datastream.Username = 'XXXXXXX')
options(Datastream.Password = 'XXXXXXXX')
mydsws <- dsws$new()
datastream-apidsws-api
@stephen.guo
Thank you so much for the update.
It may relate to the status code 470. From this page, the status code 470 is still unassigned.
I think that this is why it shows the following error when processing the status code 470.
From the error message: "Action: Deny. No rule matched. Proceeding with default action", it could be settings in the firewall that block this connection. You may need to contact your local IT support team to verify the problem.
Many thanks! I think it makes sense.
11.5k 16 7 10
Hello @stephen.guo
I cannot replicate the issue with my R version 4.0.5, it can initialize a connection successfully.
Basically, the DatastreamDSWS2R is a wrapper API for the DataStream WebServices http://product.datastream.com API endpoint. Can you access the
http://product.datastream.com URL or http://product.datastream.com/DswsClient/v1/DSService.svc/rest/help from your network?
Additionally, the DatastreamDSWS2R is a 3rd Party library that not develop and maintain by Refinitiv, you may submit the issue in the GitHub issue page directly.
@stephen.guo
You can run the below code to verify the problem.
library(httr)
DatastreamUsername <- "Username"
DatastreamPassword <- "Password"
token_url <- paste("http://product.datastream.com/DSWSClient/V1/DSService.svc/rest/Token?username=",
                   DatastreamUsername,
                   "&password=",
                  DatastreamPassword,
                   sep="")
test <- httr::GET(token_url, httr::timeout(300))
print(test)
print(status_code(test))
print(headers(test))
print(content(test))
After running, please remove your credential from the output and share it.
@jirapongse.phuriphanvichai
Many thanks for your help here! I have run your test code and getting the following results.
library('httr')
> DatastreamUsername <- "username"
> DatastreamPassword <- "password"
+ DatastreamUsername,
+ "&password=",
+ DatastreamPassword,
+ sep="")
> print(test)
Response [http://product.datastream.com/DSWSClient/V1/DSService.svc/rest/Token?username=username&password=password]
Date: 2021-05-19 06:14
Status: 470
Content-Type: text/plain; charset=utf-8
[1] 470
$date
[1] "Wed, 19 May 2021 06:14:14 GMT"
$`content-length`
[1] "199"
$`content-type`
[1] "text/plain; charset=utf-8"
attr(,"class")
[1] "insensitive" "list"
[1] "HTTP request from 10.190.168.182:56148 to product.datastream.com:80. Url: product.datastream.com/DSWSClient/V1/DSService.svc/rest/Token. Action: Deny. No rule matched. Proceeding with default action"
11.5k 16 7 10
Hello @stephen.guo
The error message "Deny. No rule matched. Proceeding with default action " means your network blocks access to the DataStream API endpoint (product.datastream.com) .
I suggest you contact your IT Network team to help you.
