4 digit prices on EUR=, GBP=
Hi there,
Current I notice that real time market price on EUR= and GBP= has only 4 digits. I am using trial account in order evaluate your service. Is there any special parameter which I need to supply for 5-digit price when I request through RDP Optimized by .NET ?
Regards,
Hassan
websocketsrrtorefinitiv-realtime-optimised
Hi @hasanderonn
When you say 4 digits, do you mean after the decimal point? I mostly see 4 digits after the decimal point - although occasionally I do see 3.
We are limited by the source data we receive from the provider/source/exchange etc. So, if a particular contributor has sent us a a value with fewer decimal places, then that is all we can publish downstream.
However, the moderators on this forum are not content specialists. If you wish to discuss this further with a content specialist please raise a Content ticket at MyRefinitiv to discuss further with a content specialist.
Hello @hasanderonn,
The maximum resolution of FX pricing data is 4 digits in Refinitiv Real time Optimized. I believe this data is sourced from dealing network, where minimum quotable/tradable unit is 1 pip. The data resolution for FX is 4 digits across all the other Refinitiv products as well.
I would recommend that you contact content support at my.refinitiv.com to talk to a content expert about this.
Thank you for your suggestion.
Regards,
Hasson
