News retrieval using rdp.get_news_story
Hi Team,
I am trying to pull in news stories using rdp.get_news_story, but no format seems to be working
I am using a dedicated RDP account and I can pull in headlines just fine ex. using
rdp.get_news_headlines(query="R:VOD.L AND LEN", date_from="2021-03-06T09:00:00", \
                       date_to="2021-03-08T18:00:00", count=10, sort_order='newToOld')
but the subsequent story retrieval isn't working ex. for story ID urn:newsml:reuters.com:20210308:nBw12DM8da:1
I would assume it would behave the same way as eikon DAPI where I just need to supply the ID/PNAC string but the below don't work
rdp.get_news_story(story_id='urn:newsml:reuters.com:20210308:nBw12DM8da:1')
rdp.get_news_story(story_id='nBw12DM8da')
I also tried parsing the url into the same format indicated in the context menu for the function, but still no luck
import urllib
test = urllib.parse.quote('urn:newsml:reuters.com:20210308:nBw12DM8da:1', \
                          encoding='utf-8', errors='replace')
rdp.get_news_story(story_id=test)
Any hints how to access the story using that ID?
rdp-apirefinitiv-data-platformnewsrefinitiv-data-platform-libraries
Hi @leszek.lubecki,
I think this is a shortcoming in the RDP Python library. The library is sending in an accept header with */*, where as the documentation clearly mentions that only text/html or application/json is accepted. The server response is different based on what the application sends in accept header.
RDP library:
GET https://api.refinitiv.com/data/news/v1/stories/urn%3Anewsml%3Areuters.com%3A20210308%3AnBw12DM8da%3A1 HTTP/1.1
host: api.refinitiv.com
user-agent: python-httpx/0.14.3
accept: */*
accept-encoding: gzip, deflate
connection: keep-alive
authorization: Bearer ***
x-tr-applicationid: D6D7***DDD74
Here is the description in the RDP documentation:
I will raise this issue with the product team. Meanwhile, if you like, you can use requests module to make your own API call to news story:
import requests
headers = {
    'Accept': 'application/json',
    'Authorization': 'Bearer **YOUR ACCESS TOKEN**'
response = requests.request("GET", "https://api.refinitiv.com/data/news/v1/stories/urn:newsml:reuters.com:20210308:nBw12DM8da:1", headers=headers, data={})
print(response.text)
9.7k 49 38 60
Hi @leszek.lubecki,
The proper way to retrieve a story is how you performed above with the following line:
Can you retrieve the status from this call? Do this:
rdp.get_last_status()
Hey @nick.zincone.1
I get this:
{'http_status_code': 400, 'http_reason': 'Bad Request', 'error': {'id': 'acac01d2-4b36-4299-bb83-364a859e59be',  'code': '400',  'message': 'Validation error',  'status': 'Bad Request',  'errors': [{'key': 'accept',    'reason': 'validation failure list:\naccept in header should be one of [application/json text/html]'}]}}
