Supported SFC C++ versions
from the latest API compatibility matrix I can see that SFC C++ Edition 4.6.3 & older versions are in active obsolescence.
Is there a lower limit? In particular I need to check if the following versions are still supported (even if in obsolescence):
  • 4.6.2L1
  • 4.6.0L1
  • 4.5.5
One more question: when this active obsolescence will expire so that the libraries will no longer be supported?
Best Regards,
Paolo
trepsfceol
@Paolo Parlapiano
I found this notification.
SFC C++ 4.6.1 and below have been end of life. From this information, we still support SFC C++ 4.6.2 or higher until further announcements.
We have contacted the product manager for confirmation.
Thank you!
