After a disconnect from the reuters server, the SFC api went into an infinite loop and I can see the following SSL logs repeatedly in the application log file.
sslPostEvent(SSL_ET_IMAGE_REQ) failed on channel 0. Reason: Wed Jan 10 00:42:35 2018 file = ssl/edapi.c, line = 7815, Channel = 0 sslSnkOpen: System Error: Event Posting failed for Event 35. Item ESE Service hEDD
Could you please help in answering the following query:
1) What does the SSL logs (highlighted above) means and why did the API went into the loop.
2) What can be done to detect and recover from this state
