Hello
The customer is evaluating RTO with EMA Java version API.
The code once actually works and can subscribe the data,
However they tried to subscribing many RICs (snapshot) every few minutes, it resulting the disconnection becomes often happen, they see below error message in the log file.
Received ChannelDownReconnecting event on channel Channel_2
(The full log message attached)
I have created the case (09805875: Optimized disconnections on 15th Apr ) to check if anything wrong at the server side, However the server log says "Connection reset by peer" which usually mean the session was disconnected from customer end.
<ads-fanout-med-az1-apse1-prd.1.ads: Info: Thu Apr 15 09:19:37.739375 2021>
RSSL disconnect from "GE-xxxx" at position "10.90.20.37/tkwaplm03b.ewarrant.com" on host "tkwaplm03b.ewarrant.com" using application "256" of version "etaj3.6.1.L1.all.rrg|emaj3.6.1.L1.all.rrg" on channel 61.
Reason: rsslRead() failed with code -1 and system error 11. Text: </local/jenkins/workspace/TREP34XCore_Release/OS/OL7-64/esdk/source/esdk/Cpp-C/Eta/Impl/Transport/rsslSocketTransportImpl.c:676> Error:1002 ipcRead() failure. Connection reset by peer
<END>
Hence the customer and I are assuming API made disconnection by some reason.
I believe the given log is not enough to make deeper analysis. Hence I would ask if the reason of disconnection can be analyzed if the customer help to make change log level?
If yes, please advise how to change the log level. According to the customer they are experiencing the same disconnection but different timing every day. Replication of the problem should be made easily.
Appreciated for your advice
Best regards
Noboru Maruyama
