Datastream Chart Export Add-In - Workspace Online
I need to export some charts from DSCHART Library to MS Powerpoint using the Web Version of Workspace.
In the export pop=up, it says I need to install an add-in for this, but the page for the add-in doesn't work anymore. Is there a way I can export charts from DSCHART Library into Powerpoint from Workspace Web Version?
datastream-apidsws-api
@Edward.Pemberton
Good day!
Unfortunately export to PowerPoint and other Office applications is not supported in Workspace Web. The export icons should not be displayed and will be removed in due course.
So to use that export feature you need to have desktop version installed and charting add in enabled.
Regards,
Balagouda Patil
Product Specialist, Asset Management
