Error occurred whilst connecting Redi API via Python
Downloaded the Python script provided in the FTP, however, when I tried to run the Python program, named ‘Order Entry – Equities Futures.py’, it gave me the following error messages:
File "C:\Users\Admin\anaconda3\lib\site-packages\win32com\client\dynamic.py", line 89, in _GetGoodDispatch
IDispatch = pythoncom.connect(IDispatch)
com_error: (-2147221005, 'Invalid class string', None, None)
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
File "C:\Users\Admin\Desktop\Order Entry - Equities & Futures.py", line 36, in <module>
o = win32com.client.Dispatch("REDI.ORDER")
File "C:\Users\Admin\anaconda3\lib\site-packages\win32com\client\__init__.py", line 95, in Dispatch
dispatch, userName = dynamic._GetGoodDispatchAndUserName(dispatch,userName,clsctx)
File "C:\Users\Admin\anaconda3\lib\site-packages\win32com\client\dynamic.py", line 114, in _GetGoodDispatchAndUserName
return (_GetGoodDispatch(IDispatch, clsctx), userName)
File "C:\Users\Admin\anaconda3\lib\site-packages\win32com\client\dynamic.py", line 91, in _GetGoodDispatch
IDispatch = pythoncom.CoCreateInstance(IDispatch, None, clsctx, pythoncom.IID_IDispatch)
I can run win32com library and try to connect to Word application and it works well on my 64-bit system. Could someone please take a look at the problem and advice how to fix it?
Had tried to find the answer from the forum however, solution is suggesting us to go through step 5 in quick start. There is only solution for excel api in step 5, not python.
redi-api
Hello @wadehong,
I am also running on win 64 bit - just tested -the example runs as expected from my testing.
A quick sanity check:
  • Your REDIPlus desktop is running and the user is logged in, when you test?
  • Which version of win32 are you running?
python -m pip freeze | findstr 32
pywin32==300
Hi, thanks for your help, I have just updated pywin32 version to 300, however it still doesn't work and keeps showing this kind of error: com_error: (-2147221005, 'Invalid class string', None, None)
I think it 's due to the connection error to REDIPlus. and I have already opened RediPlus.
Can u provide a more professional solution?
23k 22 9 14
Hello @wadehong,
Please confirm:
  • Your REDIPlus desktop is running, and your user is logged in when you submit the request
  • Try REDIPlus -> Troubleshooting ->Reregister Files
  • Verify your version of python
  • You are running the python example on the same machine at the same time that your logged in REDIPlus desktop is running?
  • The example is not modified, other then your unique submission parameters?
