interval parameter doesn't work
Hello.
I want to get weekly or monthly data using historical price summary function, but only I can get daily data.
Should I use another RIC code or function? Please help me. Thanks a lot.
col = ['CMCU3']
start_date = '2019-01-01T00:00:00'
end_date =  '2021-02-01T00:00:00'
df1 = rdp.get_historical_price_summaries(univers = col, interval = rdp.Intervals.WEEKLY, start = start_date, end = end_date)
rdp-apirefinitiv-data-platformrefinitiv-data-platform-libraries
@lsibobe
It could be a bug in the library.
The workaround could be like the following.
col = 'CMCU3'
start_date = '2019-01-01'
end_date =  '2021-02-01'
endpoint = rdp.Endpoint(
    session = rdp.get_default_session(), # Optionnal
    url = "/data/historical-pricing/v1/views/interday-summaries/"+col)
response = endpoint.send_request(
    method = rdp.Endpoint.RequestMethod.GET,
    query_parameters={
        'interval': 'P1W',
        'start': start_date,
        'end': end_date
if response.is_success:
    headers = [h['name'] for h in response.data.raw[0]['headers']]
    df = pd.DataFrame(data=response.data.raw[0]['data'], columns=headers)
    display(df)
For monthly data, the interval value is P1M.
Thanks a lot, it works! Is there any API or references about this codes???
@lsibobe
It demonstrates how to directly connect to the RDP endpoint and retrieve the data. The example code is available on GitHub.
To use the historical endpoint, please refer to the API doc.
