Using Dot Net Core to login RTH "The remote certificate is invalid according to the validation procedure"
Hi team,
I'm using .NET Core to login RTH with IP 164.57.211.94 (cannot access *.reuters.com due to ISP network limitation), not the .NET Framework. It prompted "The remote certificate is invalid according to the validation procedure". Actually it will be OK if I use .NET Framework and add the ServicePointManager.ServerCertificateValidationCallback += (o, c, ch, er) => true;. But it does not work for .NET Core (e.g., https://stackoverflow.com/questions/38138952/bypass-invalid-ssl-certificate-in-net-core).
How to overcome this? As my main project is based on .NET Core.
23k 22 9 14
Hello @Frederic,
.NET Core is not supported with RTH .NET SDK,
Please refer to previous discussion thread for more explanation and this previous discussion thread for a possible approach.
