"Domain type does not match existing request." in EMA API C++ Sample code consummer11
We are having issues with EMA API C++ Sample code consummer113. The sample code was found to have this problem today. It used to work ok.
loggerMsg
TimeStamp: 13:42:52.398
Severity: Success
Text: Received ChannelUp event on channel Channel_3
Instance Name Consumer_3_1
Connected component version: ads3.4.2.L1.linux.tis.rrg 64-bit
loggerMsgEnd
loggerMsg
TimeStamp: 13:42:53.167
ClientName: SingleItem
Severity: Error
Text: Internal error: rsslReactorSubmitMsg() failed in SingleItem::submit( RsslRequestMsg* )
RsslChannel 0x(nil)
Error Id -29
Internal sysError 0
Error Location /r/emalib/Cpp-C/Eta/Impl/Reactor/Watchlist/wlItem.c:697
Error Text Domain type does not match existing request.
loggerMsgEnd
loggerMsg
ClientName: Consumer_3_1
Severity: Error
Text: Failed to open or modify item request. Reason: RSSL_RET_INVALID_DATA. Error text: Domain type does not match existing request.
loggerMsgEnd
Exception Type='OmmInvalidUsageException', Text='Failed to open or modify item request. Reason: RSSL_RET_INVALID_DATA. Error text: Domain type does not match existing request.', ErrorCode='-29'
Best regards,
Yongguang
@yongguang.wang
From my checking, I assume that you are using EMA 3.5.0.L1 in Real-Time SDK C/CPP 1.5.0.L1.
It looks like to be a bug fixed in EMA C++ 3.5.1.L1 in RTSDK C++/C Release 1.5.1.L1.
- [ESDK-4086] - EMA must check both DictionaryUsed and DictionaryProvided to download dictionary from network
The workaround for EMA 3.5.0.L1 is loading the dictionary from the local files by using Dictionary_2 in Consumer_3.
    <Consumer>
      <Name value="Consumer_3"/>
      <!-- ChannelSet specifies an ordered list of Channels to which OmmConsumer will attempt to    -->
      <!-- connect, one at a time, if the previous one fails to connect                            -->
      <ChannelSet value="Channel_3"/>
      <Logger value="Logger_1"/>
      <Dictionary value="Dictionary_2"/>
      <XmlTraceToStdout value="0"/>
    </Consumer>
        <Dictionary>
            <Name value="Dictionary_2"/>
            <DictionaryType value="DictionaryType::FileDictionary"/>
            <!-- dictionary names are optional: defaulted to RDMFieldDictionary and enumtype.def -->
            <RdmFieldDictionaryFileName value="./RDMFieldDictionary"/>
            <EnumTypeDefFileName value="./enumtype.def"/>
        </Dictionary>
Then, copy the RDMFieldDictionary and enumtype.def files from the Cpp-C\etc to the working directory of the application.
Otherwise, you can upgrade to the latest version of the Refinitiv Real-Time SDK.
