switch from using Active to Expired RIC for listed Futures contract
I have a question regarding expired future contract.
At which time exactly we switch from active RIC to Expired RIC .
Example :
Consider EUREX Bond futures March 2021 ,
Active RIC was FGBLH1. The expiry date is 12/08/2021.The expired RIC is FGBLH1^2.
When can we start using the expired RIC ? Is there a period of time around expiry date we can use Both RICS FGBH1 and FGBLH1^2 ? If not how much time after contract Expiry we can query using Expiry RIC FGBLH1^2.
dss-rest-apidatascope-selectdssexpired-contract
Refinitiv support answer :
Please note that the standard number of days the RIC will have a delisted syntax “^2” is 4 days after the Expiry Date, and RICs <FGBLH1> and <FGBLH1^2> cannot co-exist as we do not maintain duplicate RICs.
For the given example:
The Expiry Date was 08-Mar-2021, and the RIC was retired on 12-Mar-2021 and changed to FGBLH1^2. Hence you can start using the retired RIC 4 days after the Expiry Date.
23k 22 9 14
Hello @benyounes.benali-ext,
This forum is dedicated to questions centered around API usage, the majority of the forum's members are Refinitiv API developers, the moderators are Refinitiv API experts.
Refinitiv provides many different types of content, and as a customer, Refinitiv content experts can help you navigate your way through that sea of content to finding the content that meets your requirements, The most efficient way to proceed is to contact them about content questions directly, via Refinitiv Helpdesk Online -> Content -> DSS
At present, I have opened a content investigation support case on your behalf, #09743219 , please expect to be contacted for the follow-up via email address that you have registered on developers portal with.
