Not getting info from TR.IssuerRating
Hi, I am using the following code:
CORP_COLOMB_US = ['ES122321657=','CO080166524=','CO089109256=','CO141154222=','CO165899431=','CO081101035=' ]
ts2,e2 = ek.get_data(CORP_COLOMB_US,
["TR.BENCHMARKSPREAD.date","TR.BENCHMARKSPREAD","TR.ASSETSWAPSPREAD","TR.MODIFIEDDURATION"],
{'SDate':start_date,'EDate':end_date,'Frq':'D'})
This works fine. However, when I add the field TR.IssuerRating it doesn't work anymore. I looked in the Data Item Browser and the field is supposed to work with historic information as is shown in the picture below.
How should I correct the code in order to get that information?
Thanks!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonissue
18k 21 12 20
Hi @andrgome
I think you can try this code:
start_date = "2015-12-31"
end_date = "2021-03-15"
RICs= ['195325BN4=','USP3772NHK11=','195325BQ7=','CO018437384=','195325CX1=','CO007401060=',
'195325DL6=','CO010878659=','195325DP7=','195325DR3=','195325DS1=','CO016187933=',
'CO026779405=','195325BM6=','195325BR5=','195325CU7=','195325DQ5=','195325DT9=','195325DX0='] #YANKEES COLOMBIA
fields3 = ["TR.IssuerRating","TR.IR.RatingDate"]
ts1,e1 = ek.get_data(RICs,fields3,{'SDate':start_date,'EDate':end_date,'Frq':'D'})
ts2 = ts1.loc[ts1['Date'] != '']
ts2
Thanks! this helps!
18k 21 12 20
Hi @andrgome
I believe that the start_date and end_date that you input to the API call, does not include the date the issuer rating is calculated.
For example, if the date include 8th April 2020, you would get the result.
Thanks for your answer. I tried to do what you explained but it didn't work.
Look the code that I wrote.
start_date = "2019-12-31"
'CO026779405','195325BM6=','195325BR5=','195325CU7=','195325DQ5=','195325DT9=','195325DX0='] #YANKEES COLOMBIA
ts1
I got an empty dataframe. What should I do?
Thanks!
Hi @andrgome
I am not a content expert but I believe that it does not make sense to query Issuer Rating with a start date and end date.
Please try this code: (note that CO026779405 should be CO026779405=)
ts1,e1 = ek.get_data(RICs,fields3)
ts1
Thanks for your answer. Indeed, when I used the formula without start and end date it works. However I woul like to have it for a time series because I would like to see when an issuer is downgraded or upgraded and the different rating levels.
Thanks anyway for taking a look.
