Issue getting credit ratings data with Python
Hello! I am trying to download all flavors of Fitch credit rating for Alinma Bank (1150.SE) with Eikon DAPI (Python). The formula that I am using is correct and returns ratings for other entities, but not for Alinma Bank, unfortunately. I basically go through all Fitch rating sources as indicated in the RATMON file. There is no problem with the formula, it is correct.
Fitch_rating, err = ek.get_data(instruments=["1150.SE"],fields=['TR.IssuerRating(IssuerRatingSrc=FIS)','TR.IssuerRating(IssuerRatingSrc=FSS)','TR.IssuerRating(IssuerRatingSrc=FDL)','TR.IssuerRating(IssuerRatingSrc=FDS)','TR.IssuerRating(IssuerRatingSrc=FBB)','TR.IssuerRating(IssuerRatingSrc=FBD)','TR.IssuerRating(IssuerRatingSrc=FBN)','TR.IssuerRating(IssuerRatingSrc=FBP)','TR.IssuerRating(IssuerRatingSrc=FBR)','TR.IssuerRating(IssuerRatingSrc=FBS)','TR.IssuerRating(IssuerRatingSrc=FBU)','TR.IssuerRating(IssuerRatingSrc=FBV)','TR.IssuerRating(IssuerRatingSrc=FCP)','TR.IssuerRating(IssuerRatingSrc=FDT)','TR.IssuerRating(IssuerRatingSrc=FFN)','TR.IssuerRating(IssuerRatingSrc=FFQ)','TR.IssuerRating(IssuerRatingSrc=FIF)','TR.IssuerRating(IssuerRatingSrc=FIN)','TR.IssuerRating(IssuerRatingSrc=FIV)','TR.IssuerRating(IssuerRatingSrc=FJB)','TR.IssuerRating(IssuerRatingSrc=FMC)','TR.IssuerRating(IssuerRatingSrc=FME)','TR.IssuerRating(IssuerRatingSrc=FMO)','TR.IssuerRating(IssuerRatingSrc=FMT)','TR.IssuerRating(IssuerRatingSrc=FMU)','TR.IssuerRating(IssuerRatingSrc=FNQ)','TR.IssuerRating(IssuerRatingSrc=FOC)','TR.IssuerRating(IssuerRatingSrc=FPC)','TR.IssuerRating(IssuerRatingSrc=FSB)','TR.IssuerRating(IssuerRatingSrc=FSC)','TR.IssuerRating(IssuerRatingSrc=FSE)','TR.IssuerRating(IssuerRatingSrc=FSF)','TR.IssuerRating(IssuerRatingSrc=FSR)'])
What it returns is NaN (empty) for all fields, although Eikon Terminal shows that there is a BBB+ rating for Fitch Long-Term Issuer Default Rating (rating source code=FDL), please see in the formula above. What is the issue with that? Many thanks for your help!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonbondsissue
3.8k 4 4 6
Hi @oleksandr.yermolayev
Try this one:
ek.get_data('1150.SE', ['TR.IssuerRating.date','TR.IssuerRating.RatingSourceDescription','TR.IssuerRating'], {'IssuerRatingSrc':'FBS:FSF:FDL', 'RatingScope':'All'})
@ Many thanks for the formula, however the aim is different. The point is to be able to get all possible ratings for a list of issuers (e.g. 200 issuers) in an automated fashion and there is no issue with my formula as it returns ratings for other entities. So i cannot tailor the formula to each separate issuer, I just need to screen all ratings.
Can the problem be that the Fitch Long-Term Issuer Default Rating (FDL rating) is with the attribute "Foreign"? How should I modify the 'TR.IssuerRating(IssuerRatingSrc=FDL)' to reflect the FRN type? Just adding FDL FRN does not work.
I suggest then to try:
ek.get_data('1150.SE',['TR.IssuerRating.date','TR.IssuerRating.RatingSourceDescription','TR.IssuerRating.ScopeDescription','TR.IssuerRating'],{'IssuerRatingSrc':'FIS:FSS:FDL:FDS:FBB:FBD:FBN:FBP:FBR:FBS:FBU:FBV:FCP:FDT:FFN:FFQ:FIF:FIN:FIV:FJB:FMC:FME:FMO:FMT:FMU:FNQ:FOC:FPC:FSB:FSC:FSE:FSF:FSR', 'RatingScope':'All'})
@ Many thanks for this formula, this is much better and serves its purpose perfectly
