The issue was investigated by RDC support team and the case is closed with the following resolution comment:
"The possible root causes are network/firewall issue, ADS is down, ADS server is shutdown, ADS does not response. The actual root cause cannot be determined due to lack of RFA trace log."
Hello @ramy.refaat
Do you mean the RFA Java application is disconnected from the Refinitiv Real-Time infra, but on the infra side (e.g. ADS server) is still working fine?
If so, could you please give us more details about when the problem occurred?
You can configure the following RFA Java configurations to enable the log file
Hello @ramy.refaat
It seems you have submitted the API ticket to the RDC support team regarding this issue. The RDC team is working on the issue and you can follow-up via the RDC team directly.
