Static data which API to use with .NET
Ca you please suggest which Reuters .NET API is best suitable for getting static data for equities such as SEDOL, ISIN?
Thanks for info,
Petr
treprfarfa-apiapi.netstatic-data
My apologies. I misread your question. For some reason I thought you were asking what Eikon APIs you could use to retrieve static data.
Since you're actually interested in consuming data in an enterprise application the product you should look at is Datascope Select. RFA API can only deliver market data from Thomson Reuters real-time data network known as Elektron. For static data you need Datascope Select. Please follow the link below for the Datascope Select page on this portal.
https://developers.refinitiv.com/en/datascope-select-dss
Great. I'll look at this. Thanks.
If the only static data you need is symbology conversion for equities, then you can use Symbology service of Eikon .NET API. See
https://developers.refinitiv.com/en/api-catalog/eikon/-net-apis-for-use-in-custom-applications/tutorials#symbology
But if you also need fundamental and reference data for stocks then you should use DEX2 COM library instead
https://developers.refinitiv.com/en/api-catalog/eikon/com-apis-for-use-in-custom-applications/tutorials#tutorial-3-fundamental-and-reference-data
Thanks for your response Alex. I'll check it.
Both these libraries require Eikon desktop package to be installed on the same computer. Is there some standalone API library (for getting Reuters static data) which is suitable to run on server?
Can possibly be RFA API be used to get static data?
7.6k 15 6 9
petr.synek
RFA API and other TREP APIs can not used to request static data for equities such as SEDOL, ISIN. Baiscally it support only Real-Time market data from Elektron for RealTime. And user has to know RIC name in advance when request the data.
As Alex said the product you should look at is Datascope Select.
