How to get Quote PermID back in EquitySearch?
Hi - I'm trying to use the search API/EquitySearch to search by ISIN and get back Quote PermID as my preferred identifier. I know it's possible, because I can do it in the UI.
However, in the Identifier enum, there is no option for Quote PermID, only PID, which I think is entity perm ID.
To make matters more confusing, when I try to pass in some identifier types in the search, such as Pix, I get back the error:
ThomsonReuters.Dss.Api.ValidationException: 'Validation Error:
The Preferred Identifier Type Code PIX is not supported; supported values are: RIC, CSP, ISN, VAL, WPK, COM, SED, PID, PIDQ, SIC, SVM, MIC, CIN, SYM'
I'm pretty sure PIDQ is quote perm ID, but I don't see any way to pass this in.
What is wrong here?
Thanks.
dss-rest-apidatascope-selectdsspermid-api
@waynes
This issue will be fixed in the next release (15.0).
DataScope Select v15.0 has been released in June 2021. Release notes are available following the link below.
https://my.refinitiv.com/content/dam/myrefinitiv/products/8179/en/Technical/629605.pdf
@waynes
I can replicate the issue. I will report it to the development team.
I will let you know after receiving any response back from them.
Thank you. Do you know if there is another way to pass in an ISIN and get back all Quote Perm IDs? It seems in a terms and conditions extraction, when passing in ISIN, it only returns back to the primary instrument. I want to get all of the exchanges for the ISIN back if possible.
Thanks.
You can use EquitySearch to get all RICs and then use RICs with the terms and conditions extraction to get Quote PermID.
...Also, do you have any idea how long it could take to get a fix for this issue?
The development team is verifying this issue. I will keep you informed.
@waynes
The DSS 15.0 release has been postponed. The tentative date is around Jun 2021.
