EMA Java failover
I'm using ChannelSet to configure multiple TREPs hosts to make failover when one is down.
<ChannelSet value="Channel_1,Channel_2,Channel_3,Channel_4" />
I tested and work fine, the application initially connect to Channel_1 and when down connecting to Channel_2.
My question is when connected to Channel_4, if it is down, the Api will try to connect back to Channel_1 or not?
Stephane
11.5k 16 7 10
Hello @Stephane Rossi
I have tested 3 channels (as I currently have only 3 ADS in my environment - they are all ADS 3.x versions) with the following configuration:
<ChannelSet value="Channel_1, Channel_2, Channel_3"/>
When Channel_3 is down, the application connects back to Channel_1 successfully.
Please note that it is recommended to use the same version of the ADS server and each server has the same services for the API failover feature.
Hi @Stephane Rossi
My understanding is that it should rotate back round to Channel_1.
I will seek confirmation and get back to you.
Many thanks for the confirmation
