ODPS API usage not being captured in DACS usage report
SUCCESS:
Feb 18 15:23:01:INFO:<IP> Cmd=subscriptionTest RespTime=1 RespSize=103 (ODPS_003401)
Feb 18 15:23:01:INFO:<IP> [780706] (ODPS_003402)
GET /?user=<USERNAME>&position=<IP>/<USERNAME>&application=513&service=<FEED>&command=subscriptionTest&item=KS200450I1.KS&closure=<USERNAME>:946ec193-f140-443e-ac5e-ae41259d3b95&domain=HKG&usage=always HTTP/1.1
Host: opendacs.domain.net:8089
Connection: Keep-Alive
Accept-Encoding: gzip
User-Agent: okhttp/3.9.0
DACSopen-dacs
23k 22 9 14
Hello @Charles Hui,
I do not believe that the issue described has to do with OpenDACS API usage, rather ODPS implements OpenDACS and submits the requests, fully encapsulating the semantics of OpenDACS API. These forums are most effective for questions and discussions centrred around Refinitiv API usage,
Rather, I think this question is related to the local environment, ODPS and the underlying DACS installation and configuration.
I think the best way to troubleshoot this type of issue for a customer is via Refinitiv Helpdesk Online -> Support -> Product does not work as expected -> Select product Refinitiv Realtime Open DACS Permission Server.
Hi Charles,
Make sure the dacs_snkd the ODPS is using has the following parameters set in the dacs.env
DACS_SNKD_P2P_USAGE
DACS_SNKD_P2P_USAGE_SIZE
You can find which dacs_snkd it's using by looking at the server name in in the following odps.cfg parameter as this could be installed locally or on another server.
\PermissionServer\multiconnect.DB.connectinfo
Also make sure \PermissionServer\multiconnect.<DOMAINNAME GOES HERE>.usage-logging is set to 'always'
Regards Paul
