Block Trades fields in DataScope only available for certain Exchanges?
I am trying to retrieve any of the "Block ..." fields in DataScope, from the CompositeExtractionRequest
But I seem to only get nulls returned, and a zero for "Block Trades Grade", for any stocks on the Australian ASX
If I run for other large stocks though, like Amazon or IBM, I do get non-null values returned
My question is, should I see the nulls returned for ASX stocks as being zero, or that DataScope does not have any of these values?
I've put my Postman script below, any help would be appreciated, thanks
    "ExtractionRequest": {
        "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.CompositeExtractionRequest",
        "ContentFieldNames": [
            "Block Trades",
            "Block Volume"
        "IdentifierList": {
            "InstrumentIdentifiers": [
                  { "Identifier": "IBM.N", "IdentifierType": "Ric" },
                { "Identifier": "AMZN.O", "IdentifierType": "Ric" },
                { "Identifier": "BHP.AX", "IdentifierType": "Ric" },
                { "Identifier": "ANZ.AX", "IdentifierType": "Ric" },
                { "Identifier": "WOW.AX", "IdentifierType": "Ric" }
@Pocari Sweat
Yes, you are correct. It returns 0 and null for ASX stocks.
            "IdentifierType": "Ric",
            "Block Trades": null,
            "Block Trades Grade": 0,
            "Block Volume": null
To verify the content, please directly contact the Refinitiv DataScope Select team via MyRefinitiv to verify the problem.
@Pocari Sweat
I am unable to confirm it. Please directly contact the Refinitiv DataScope Select team to verify it.
