I need to download the constituents of Russell 3000 for a certain month via DataStream. At the moment I am using the mnemonic 'LFRUSSL3' but it does not outputs any values (empty result); I also tried the codes LFRUSS3L, LFRU05L3 etc but they all give the same output (empty). The code I am using (via the DataStream function ds.get_data) works for all the other markets. Is the mnemonic wrong? If so, which one should I use?
