API Rebranding - Is SFC impacted?
this is a double check question.
From the API Rebranding, Version 1.1, I understand that SFC C++ is not impacted in the rebranding activity, so clients using SFC are not requested to do anything.
Could you please confirm this?
And just for curiosity: if so, why SFC is not impacted?
Best Regards,
Paolo
rdp-apirefinitiv-data-platformrefinitiv-data-platform-libraries
Hi @Paolo Parlapiano
As per the above rebranding notification, the key objective is to remove "Thomson Reuters" related references from our affected APIs.
The SFC APIs may use 'Thomson Reuters' references in the documentation, but do not use "Thomson Reuters" related namespaces/class names etc - therefore there is no code related impact.
Thank you for the prompt reply @umer.nalla.
Best Regards,
Paolo
