is it possible to get the field X_RIC_NAME using an SFC C++ consumer via SSL/MarketFeed?
The application is configured to download the data dictionary from Network, and actually I see such field in the dictionary, with IFD = -1.
However, when subscribing to a RIC expected to contain a value for such field, I get an image not containing X_RIC_NAME at all (we've enabled the IPCTRACE files to double check it).
Is there any known limitation in SFC explaining this?
In addition, could you please help me understand why some fields in the data dictionary have a negative number as FID?
Best Regards,
Paolo
