Unable to download OpenDacs SDK - What means ReLoginUserPass?
It's not possible anymore to download the Java Open DACS SDK from following link: https://developers.refinitiv.com/en/api-catalog/thomson-reuters-enterprise-platform/open-data-access-control-system-api-java/downloads
It shows 404 not found.
We need the documentation (Java Developer Guide), to know why a customers client is receiving following event and how we have to handle it: "ReLoginUserPass". We don't know what this event means and how the receiving application should handle it.
Thanks in adavance!
DACSopen-dacs
Hi @kaiping
I have reported your issue to the Developer Portal Support team - who are investigating.
In the meantime, I have been advised that they are able to recreate intermittently - so please try again a few times and see if it succeeds.
Hi @kaiping
I have been advised that a reLoginUserPass means that the user being referred to has had their permissions updated on the DACS system
As such, the application must re-permission each opened streaming item of that user to verify all content is still allowed to the user.
Hi @umer.nalla
thanks for your help!
Do you also have information about the ReLoginUserPass Event?
kind regards
Thanks for your help @umer.nalla!
I have a last question.
What is the best way to identify this event in the processEvent(...) callback?
Because the ReLoginUserPass is not part of one of following EventMsg/EventStatus classes
AuthorizationAgentEventMsg
AuthorizationAgentEventStatus
Thanks in advance!
Hi @kaiping
Can you confirm how or where you are receiving the ReLoginPass value in terms of the OpenDacs API?
In terms of your final query, please refer to the documentation for AuthorizationAgentEvent and AuthorizationAgentEventStatus.
You will find that AuthorizationAgentEvent will return a getStatus() of type AuthorizationAgentEventStatus(). If you check possible return values, you will note there is a DO_REPERMISSION status Code. This is the event type that indicates that your application needs to re-permission any open items to confirm access is still allowed.
Also, if you were unable to download the SDK from the Developer portal, you can try and access it from the My.Refintiv Software Download section too
Search Downloads/Loadview | MyRefinitiv
Hi @umer.nalla,
our client saw this event a couple of times in their environment using our software.
The software uses the OpenDacs API for login/logout/permission checks of client requests. They said this occurs without changing any permissions for the specific user. Anyway, we'll obeserve this behaviour and try how it goes with logging out the specific username from each host.
Thanks for links, they're working perfectly!
So that means, that a ReloginUserPass is actually the same (or can be handle) as a DO_REPERMISSION event?
Hi @kaiping
Yes, I checked with our Dacs expert and he confirmed the ReLoginPass relates to rechecking permissions of the user.
As per my earlier email, can you confirm how/where exactly you are getting or seeing this ReloginUserPass value? Which event or message etc are they seeing this value?
