RFA JAVA log checking on behalf of client
Client is using RFA JAVA to connect to EED to retrieve data. On Jan 9th EED EDGESHA0133 has an update of hardware and after the upgrade client found they cannot get some of the RIC update on Jan 11th . Sample RIC is AUD=. After restarting the application, client got service restored. Checked with Enterprise team and Edge device is working normally. But they found that client’s RIC list of subscription is less than it was from EED dump file after the upgrade. According to client’s side, they made no changes and they could also see AUD= message requesting for update. Since the client is quite important to us, we might need help from Dev team to check why the issue happened. Attached is the logs of Jan9th and Jan11th.
<?xml version="1.0" encoding="GB18030" standalone="no"?>
<!DOCTYPE log SYSTEM "logger.dtd">
<log>
<record>
<date>2021-01-11T18:19:24</date>
<millis>1610360364288</millis>
<sequence>8</sequence>
<logger>com.reuters.rsslc.0</logger>
<level>FINER</level>
<class>com.reuters.ipc.TraceLogger</class>
<method>traceData</method>
<thread>192</thread>
<message>
Thread: aNamespace::consSession Session EventQueueGroup
Connection 0
RSSL Transport attempt to connected to 10.208.91.10:14002
</message>
</record>
<record>
<millis>1610360364330</millis>
<sequence>9</sequence>
<message>
Connection 0
RSSL Transport connected to 10.208.91.10:14002
</message>
</record>
elektronrefinitiv-realtimetreprfa
supergwfront-biz-service.log-2021-01-11 18:33:31,271 [/// - ] INFO reuters.SimpleConsumer - [81--]cleanup: Context.string->
supergwfront-biz-service.log:2021-01-11 18:33:31,271 [/// - ] INFO reuters.ItemManager - [81--]unsubscribe items:[]
supergwfront-biz-service.log-2021-01-11 18:33:31,565 [/// - ] INFO reuters.GenericOmmParser - [81--]field dictionary read from RDMFieldDictionary file
supergwfront-biz-service.log-2021-01-11 18:33:31,626 [/// - ] INFO reuters.GenericOmmParser - [81--]enum dictionary read from enumtype.def file
supergwfront-biz-service.log-2021-01-11 18:33:32,024 [/// - ] INFO reuters.LoginClient - [81--]Sending login request, ommmsg=com.reuters.rfa.internal.rwf.RwfMsgParsed@246728a5
supergwfront-biz-service.log-2021-01-11 18:33:32,042 [/// - ] INFO reuters.SimpleConsumer - [203--]eventQueue.dispatch run
supergwfront-biz-service.log-2021-01-11 18:33:32,048 [/// - ] INFO reuters.LoginClient - [203--]LoginClient: processEvent: Received Login Response
supergwfront-biz-service.log-2021-01-11 18:33:32,049 [/// - ] INFO reuters.LoginClient - [203--]LoginClient: Received Login Response - MsgType.REFRESH_RESP
supergwfront-biz-service.log-2021-01-11 18:33:32,078 [/// - ] INFO impl.ServiceChecker - [81]isHealthy:true
supergwfront-biz-service.log-2021-01-11 18:33:32,210 [/// - ] INFO reuters.LoginClient - [203--]LoginClient: processEvent: Received Login Response
supergwfront-biz-service.log-2021-01-11 18:33:32,210 [/// - ] INFO reuters.LoginClient - [203--]LoginClient: Received Login STATUS OK Response
supergwfront-biz-service.log-2021-01-11 18:33:32,211 [/// - ] INFO reuters.SimpleConsumer - [203--]Login successful
supergwfront-biz-service.log:2021-01-11 18:33:32,211 [/// - ] INFO reuters.ItemManager - [203--]subscribe items:[HKDCNY2M=R, MYRSW=, MYRCNY1M=R, ISK2M=, SARCNY=R, DZDDR=BCAX, NOUTL=, QAR1M=, NOK5M=, ZARCNYON=R, CZK=, HKDCNH=R, CADCNY1M=R, ILPRIME=, SAR9M=, GBPCNY6M=R, QAR=, DKDISC=, AAACNNCD1YY=SHCV, CNH2M=, CNHSN=, JPYCNYSN=R, NZD3M=, EURCNY5M=R, THBSW=, DKK9M=, CZK3Y=, HICNH3MDF=, CAD9M=, AUDCNY9M=R, ILSSW=, KRWSW=, CNY1Y=, EURVND=R, IDRON=, HKDCNYSN=R, PHP3M=, EUR9M=, EURAB6E10Y=, GBGV5YUSAC=R, GBPSB6L1Y=, DKK=, GBPSWFSR=X, HKDQM3H7Y=, ECBMRO=ECBF, TWDON=, AED9M=, KRGV5YUSAC=R, CZKSW=, DKKCNY=R, AUD5M=, BHD3Y=, JPYCNY2M=R, VND9M=, LKR2M=, BHREPO=, INR6M=, JODONDR=, CHGV5YUSAC=R, PHPCNY=R, NOGV5YUSAC=R, CAONMFR=, AAACNNCD1MY=SHCV, NOKCNY=R, JPONTARGET=, HKD2Y=, BHDSW=, SGDCNY3Y=R, AAACNNCD9MY=SHCV, CHFON=, QAR3M=, HIHKD3MD=, KZT6M=, CHFAB6L5Y=, SEK4M=, DEGV5YUSAC=R, USDAM3L8Y=, JODON=, EUR1Y=, GHPRIME=, AED1Y=, CNYSW=, JPYSB6L7Y=, CHFAB6L3Y=, EURCNYSW=R, TNTMM=, NZGV5YUSAR=R, THB1Y=, PLN=, GBPCNY2Y=R, AUDCNY=R, OMRSW=, EURCNY1Y=R, DKGV5YUSAC=R, RON6M=, PLN9M=, CNY3Y=, NZD1M=, CZK18M=, CNH4M=, UAH=, HUFBASE=, CZK1Y=, OMR=, CNY=, EURAB6E1Y=, OMRCNY=R, PLNLR=, PHP5M=, SGD9M=, BHD1M=, CNGV5YUSAC=R, SGDCNY5M=R, GBPSB6L3Y=, AA+CNNCD3MY=SHCV, INRREP=RBIA, LKR4M=, HIHKD1YD=, TRY6M=, CBTONDEPO=, PLN18M=, RWCBREPO=, INR4M=, JPY2Y=, SAR=, USDAM3L6Y=, EURCNY3M=R, USDAM3L20Y=, INRCNY6M=R, JPY1MFSR=X, EURTHB=R, QAR5M=, OMR3Y=, MYR=, EURBDT=R, CNYQM7R2Y=, MMCBR=CBMM, ALLONDR=, SEK6M=, ATGV5YUSAC=R, JPY1YFSR=X, CHF2Y=, JOGV5YUSAC=R, MXN6M=, ZARCNY6M=R, ISK6M=, KZTREFRATE=, JPYSB6L5Y=, CHFAB6L1Y=, CNYQM7R6M=, NOK9M=, JPY15M=, PAGV5YUSAC=R, CABANK=, DKUDL=, CAD5M=, LKGV5YUSAC=R, RON4M=, VND=, BEGV5YUSAC=R, HKD2M=, HKDSN=, ZARON=, GHGV5YUSAC=R, ILS9M=, KRW9M=, THB1M=, MUR3M=, GBP4M=, CNHON=, CADCNY1Y=R, CZK1M=, PLN3M=, IDGV5YUSAC=R, DKK5M=, EUR18M=, MAD=, SGD1Y=, SGDCNY9M=R, EUR5M=, HUFONRR=, AED5M=, HKDCNY2Y=R, ZMONLR=, AA+CNNCD9MY=SHCV, CHFSWFSR=X, RUB6M=, MYRCNY1Y=R, AUDCNYSW=R, CNYQM3S5Y=, AUD9M=, LKR6M=, JPY6M=, HKD15M=, GTGV5YUSAC=R, HKDCNY4M=R, SHICNY9MD=, JPYCNY2Y=R, CAD=, SARSW=, UGCBIR=, TRY4M=, MOPCNY=R, MYRCNY3M=R, VNPRIME=SBVN, NZDSW=, NZD3Y=, THPRMO=, GBP3MFSR=X, CADCNY3M=R, PLNCNY=R, USD6MFSR=X, MXGV5YUSAC=R, CNY1YD=PBOC, NGMPR=, VNDSW=, SVGV5YUSAC=R, QAR18M=, /EURIBOR2MD=, JPYCNY4M=R, GBPCNYON=R, SAR3Y=, CNYT2L=PBOC, CNYLPR1Y=, NAD6M=, CNYQM3S10Y=, OMR3M=, MYR1Y=, MZPRIME=, UAHRR=, MXN4M=, ILS1Y=, KRW1Y=, INCRR=, ZAR2Y=, HRKDISC=, AA+CNNCD1YY=SHCV, THB=, MYRCNY5M=R, EURMYR=R, KWREPO=, DKK3M=, ZARCNY2Y=R, GRGV5YUSAC=R, CAD3M=, KZBASE=NBKK, INGV5YUSAC=R, RONSN=, RON2M=, CAD18M=, NOK1Y=, AUDCNY5M=R, RUBREFRATE=, PLN5M=, JPYCNY6M=R, SGD3Y=, MUR1M=, AEREPO=, GBP1YFSR=X, CNY9M=, HIHKD1MD=, PHP1M=, GBP1MFSR=X, SHICNYSWD=, CHF15M=, AMD=, ARSCMOF7D=, GBP6M=, DKK18M=, PHP=, BHD1Y=, VND1Y=, TRYSN=, TRY2M=, SGD18M=, NZD1Y=, DZD3MRR=BCAX, MYR9M=, HUGV5YUSAC=R, CRGV5YUSAC=R, EGPONDR=CBEY, AUD1Y=, BRL=, CNYQM3S7Y=, HKDON=, AAACNNCD3MY=SHCV, INRCNYON=R, SGD=, SAR1Y=, AUDCNY3Y=R, EURONFSR=X, SGDCNYSW=R, BRTARGET=CBBR, QAR9M=, GBPINR=R, MUR=, JPYSB6L3Y=, OMR1M=, PHP1Y=, EUR1M=, DKK1M=, DKINL=, ILS5M=, CAD1M=, USDAM3L15Y=, HKD6M=, ZAR2M=, ZARSN=, NOK3Y=, CNY18M=, JODISC=, ECBDF=ECBF, PKR3DRP=SBPK, BGBASE=, CHFCNH=R, SARRP=, EURPHP=R, BDT=, ARSCMOF1D=, AED1M=, IDR6M=, RUB2M=, CZK5M=, EURAB6E7Y=, SGDCNY1M=R, AUDCNY1Y=R, CNY3M=, MXN2M=, MXNSN=, JPSPRIME=, HUFONDR=, SGDSW=, CNYQM3S1Y=, ILGV5YUSAC=R, MUR18M=, ZAGV5YUSAC=R, SEK2Y=, KZTON=, CHF6M=, KRW=, INRON=, UYPRIME=UYBC, MURSW=, BRLCNY=R, JPY2M=, JPYSN=, HKGV5YUSAC=R, ZARCNY4M=R, CLTPM=, VND1M=, AUDCNY18M=R, AUD3Y=, NZD18M=, SAR1M=, CADCNY3Y=R, RSGV5YUSAC=R, HICNH1YDF=, USDONFSR=X, AUDSW=, SHICNY1MD=, NACBREPO=, JPYSB6L1Y=, NAD2M=, NADSN=, MYRCNY3Y=R, QAR1Y=, VEGV5YUSAC=R, RONON=, HKDCNY6M=R, CZDISC=, PHONRP=CBPH, ZARCNYSN=R, CHF3MFSR=X, NOK18M=, ILS=, CADCNY5M=R, ZARCNY2M=R, CNH2Y=, THB3M=, PHPSW=, HKD4M=, ROGV5YUSAC=R, SERP=, AED18M=, GBP2M=, GBPSN=, JPYCNYON=R, CZK3M=, VEFTAM1W=BCDV, SGDCNY=R, HKDQM3H1Y=, KRWCNY=R, EUR3M=, MUR3Y=, AED3M=, TRY15M=, PLN1M=, SGD1M=, RUB4M=, RUGV5YUSAC=R, BHD9M=, CNY5M=, NZD9M=, CHF1MFSR=X, CNYQM3S3Y=, EURCNY=R, TWD6M=, KWD=, SEKCNH=R, JPY4M=, TRYON=, PLNDP=, CHF4M=, MNT=BOMU, KW1MREPO=, JMGV5YUSAC=R, HICNH1MDF=, LKR2Y=, DZD1WRR=BCAX, AUGV5YUSAR=R, OMR5M=, AUDCNY3M=R, MYRCNYSW=R, THBCNY=R, MYR5M=, HKDCNY15M=R, SEKON=, SEK15M=, BHSWDR=, PEMPR=, QARCNY=R, NOK=, JOD6M=, NOKSW=, CZGV5YUSAC=R, MXN15M=, CADSW=, EUR=, AEDCNY=R, MYOPRTARGET=, EURSGD=R, AED3Y=, NOK1M=, JPYCNH=R, NOINL=, QAR3Y=, EUR3Y=, RON2Y=, MYRCNY9M=R, CADCNY9M=R, RON15M=, ZAR6M=, ILS1M=, KRW1M=, THB9M=, RUB15M=, XAU=, JPY3MFSR=X, CAD3Y=, OMCDFIX1M=, SAR5M=, DKK3Y=, BHD=, FIGV5YUSAC=R, HICNH1WDF=, QARSW=, CNHQM3H6M=BRKR, SGDCNY1Y=R, AUDCNY1M=R, CNH6M=, BHDCNY=R, MOP=, ZARCNY15M=R, GBP2Y=, SHICNY3MD=, MUR1Y=, BHD3M=, LKRPWKAG=CENS, PLN1Y=, HKDQM3H3Y=, EURAB6E3Y=, CHFAB6L10Y=, TRY2Y=, HIHKD1WD=, SGD3M=, MXNON=, GBPSB6L5Y=, IDR2M=, IDRSN=, CZK9M=, USD2MFSR=X, EUR2MFSR=X, GBPSB6L7Y=, TWDISC=, SAREPO=, ZAR15M=, AUD1M=, NPR=, CHF2M=, CHF1YFSR=X, KZT2M=, CHFSN=, RUB2Y=, EGPPRML=CBEY, GBPSB6L30Y=, EURCNY9M=R, INRSN=, BGGV5YUSAC=R, INR2M=, LKRON=, JPYON=, GBPCNY4M=R, JPYINR=R, ITGV5YUSAC=R, NZD=, USDAM3L4Y=, NADON=, KZGV5YUSAC=R, INRCNYSN=R, SHICNY1YD=, TZONIBR=, MYR3M=, ZAPRIME=, AEDSW=, OMR1Y=, EURKRW=R, INRCNY2M=R, CNYQM7R4Y=, HUFCNH=R, DKKSW=, SGDCNY3M=R, JPYSB6L30Y=, ISKON=, HKDQM3H10Y=, AED=, ARGV5YUSAC=R, CAD1Y=, HKDCNYON=R, JPYSWFSR=X, RONMR=, NOK3M=, PLNSW=, GBPCNY2M=R, ILS3M=, KRW3M=, CNHQM3H4Y=BRKR, ZAR4M=, GBPSB6L10Y=, MYRCNY=R, DKK1Y=, NZD5M=, EURCNY1M=R, TRYCNH=R, LBP3WRP=BDLX, MUR9M=, GBPON=, GBBASE=, INRCNY4M=R, PHP9M=, BHD5M=, MXN2Y=, PLN3Y=, AUD=, PEGV5YUSAC=R, HKDQM3H5Y=, EURAB6E5Y=, JPYSB6L10Y=, CNY1M=, HKDINR=R, CHPRIME=, AA+CNNCD1MY=SHCV, ECBMRO=, SGD5M=, TWD2M=, VNDISC=SBVN, RUBON=, AUD3M=, CADCNYSW=R, CNYQM3S9M=, AUD18M=, COIRTARGET=, IS7DDEP=, EUR6MFSR=X, VND3M=, VNDCNY=R, CADCNY=R, GBPCNYSN=R, CZKCNY=R, NZDCNY=R, EGDISC=CBEY, SAR3M=, USDAM3L2Y=, EURSW=, /EURIBOR2WD=, OMR9M=, MYR1M=, ISDP=, DOGV5YUSAC=R, EURAB6E30Y=, GBP15M=, GBPCNH=, CHFAB6L30Y=, CLGV5YUSAC=R, CNHQM3H2Y=BRKR, CHFAB6L7Y=, SEK2M=, SEKSN=, JOD2M=]
supergwfront-biz-service.log:2021-01-11 18:33:32,334 [/// - ] INFO reuters.ItemManager - [203--]本机订阅的items:[HKDCNY2M=R, MYRSW=, MYRCNY1M=R, ISK2M=, SARCNY=R, DZDDR=BCAX, NOUTL=, QAR1M=, NOK5M=, ZARCNYON=R, CZK=, HKDCNH=R, CADCNY1M=R, ILPRIME=, SAR9M=, GBPCNY6M=R, QAR=, DKDISC=, AAACNNCD1YY=SHCV, CNH2M=, CNHSN=, JPYCNYSN=R, NZD3M=, EURCNY5M=R, THBSW=, DKK9M=, CZK3Y=, HICNH3MDF=, CAD9M=, AUDCNY9M=R, ILSSW=, KRWSW=, CNY1Y=, EURVND=R, IDRON=, HKDCNYSN=R, PHP3M=, EUR9M=, EURAB6E10Y=, GBGV5YUSAC=R, GBPSB6L1Y=, DKK=, GBPSWFSR=X, HKDQM3H7Y=, ECBMRO=ECBF, TWDON=, AED9M=, KRGV5YUSAC=R, CZKSW=, DKKCNY=R, AUD5M=, BHD3Y=, JPYCNY2M=R, VND9M=, LKR2M=, BHREPO=, INR6M=, JODONDR=, CHGV5YUSAC=R, PHPCNY=R, NOGV5YUSAC=R, CAONMFR=, AAACNNCD1MY=SHCV, NOKCNY=R, JPONTARGET=, HKD2Y=, BHDSW=, SGDCNY3Y=R, AAACNNCD9MY=SHCV, CHFON=, QAR3M=, HIHKD3MD=, KZT6M=, CHFAB6L5Y=, SEK4M=, DEGV5YUSAC=R, USDAM3L8Y=, JODON=, EUR1Y=, GHPRIME=, AED1Y=, CNYSW=, JPYSB6L7Y=, CHFAB6L3Y=, EURCNYSW=R, TNTMM=, NZGV5YUSAR=R, THB1Y=, PLN=, GBPCNY2Y=R, AUDCNY=R, OMRSW=, EURCNY1Y=R, DKGV5YUSAC=R, RON6M=, PLN9M=, CNY3Y=, NZD1M=, CZK18M=, CNH4M=, UAH=, HUFBASE=, CZK1Y=, OMR=, CNY=, EURAB6E1Y=, OMRCNY=R, PLNLR=, PHP5M=, SGD9M=, BHD1M=, CNGV5YUSAC=R, SGDCNY5M=R, GBPSB6L3Y=, AA+CNNCD3MY=SHCV, INRREP=RBIA, LKR4M=, HIHKD1YD=, TRY6M=, CBTONDEPO=, PLN18M=, RWCBREPO=, INR4M=, JPY2Y=, SAR=, USDAM3L6Y=, EURCNY3M=R, USDAM3L20Y=, INRCNY6M=R, JPY1MFSR=X, EURTHB=R, QAR5M=, OMR3Y=, MYR=, EURBDT=R, CNYQM7R2Y=, MMCBR=CBMM, ALLONDR=, SEK6M=, ATGV5YUSAC=R, JPY1YFSR=X, CHF2Y=, JOGV5YUSAC=R, MXN6M=, ZARCNY6M=R, ISK6M=, KZTREFRATE=, JPYSB6L5Y=, CHFAB6L1Y=, CNYQM7R6M=, NOK9M=, JPY15M=, PAGV5YUSAC=R, CABANK=, DKUDL=, CAD5M=, LKGV5YUSAC=R, RON4M=, VND=, BEGV5YUSAC=R, HKD2M=, HKDSN=, ZARON=, GHGV5YUSAC=R, ILS9M=, KRW9M=, THB1M=, MUR3M=, GBP4M=, CNHON=, CADCNY1Y=R, CZK1M=, PLN3M=, IDGV5YUSAC=R, DKK5M=, EUR18M=, MAD=, SGD1Y=, SGDCNY9M=R, EUR5M=, HUFONRR=, AED5M=, HKDCNY2Y=R, ZMONLR=, AA+CNNCD9MY=SHCV, CHFSWFSR=X, RUB6M=, MYRCNY1Y=R, AUDCNYSW=R, CNYQM3S5Y=, AUD9M=, LKR6M=, JPY6M=, HKD15M=, GTGV5YUSAC=R, HKDCNY4M=R, SHICNY9MD=, JPYCNY2Y=R, CAD=, SARSW=, UGCBIR=, TRY4M=, MOPCNY=R, MYRCNY3M=R, VNPRIME=SBVN, NZDSW=, NZD3Y=, THPRMO=, GBP3MFSR=X, CADCNY3M=R, PLNCNY=R, USD6MFSR=X, MXGV5YUSAC=R, CNY1YD=PBOC, NGMPR=, VNDSW=, SVGV5YUSAC=R, QAR18M=, /EURIBOR2MD=, JPYCNY4M=R, GBPCNYON=R, SAR3Y=, CNYT2L=PBOC, CNYLPR1Y=, NAD6M=, CNYQM3S10Y=, OMR3M=, MYR1Y=, MZPRIME=, UAHRR=, MXN4M=, ILS1Y=, KRW1Y=, INCRR=, ZAR2Y=, HRKDISC=, AA+CNNCD1YY=SHCV, THB=, MYRCNY5M=R, EURMYR=R, KWREPO=, DKK3M=, ZARCNY2Y=R, GRGV5YUSAC=R, CAD3M=, KZBASE=NBKK, INGV5YUSAC=R, RONSN=, RON2M=, CAD18M=, NOK1Y=, AUDCNY5M=R, RUBREFRATE=, PLN5M=, JPYCNY6M=R, SGD3Y=, MUR1M=, AEREPO=, GBP1YFSR=X, CNY9M=, HIHKD1MD=, PHP1M=, GBP1MFSR=X, SHICNYSWD=, CHF15M=, AMD=, ARSCMOF7D=, GBP6M=, DKK18M=, PHP=, BHD1Y=, VND1Y=, TRYSN=, TRY2M=, SGD18M=, NZD1Y=, DZD3MRR=BCAX, MYR9M=, HUGV5YUSAC=R, CRGV5YUSAC=R, EGPONDR=CBEY, AUD1Y=, BRL=, CNYQM3S7Y=, HKDON=, AAACNNCD3MY=SHCV, INRCNYON=R, SGD=, SAR1Y=, AUDCNY3Y=R, EURONFSR=X, SGDCNYSW=R, BRTARGET=CBBR, QAR9M=, GBPINR=R, MUR=, JPYSB6L3Y=, OMR1M=, PHP1Y=, EUR1M=, DKK1M=, DKINL=, ILS5M=, CAD1M=, USDAM3L15Y=, HKD6M=, ZAR2M=, ZARSN=, NOK3Y=, CNY18M=, JODISC=, ECBDF=ECBF, PKR3DRP=SBPK, BGBASE=, CHFCNH=R, SARRP=, EURPHP=R, BDT=, ARSCMOF1D=, AED1M=, IDR6M=, RUB2M=, CZK5M=, EURAB6E7Y=, SGDCNY1M=R, AUDCNY1Y=R, CNY3M=, MXN2M=, MXNSN=, JPSPRIME=, HUFONDR=, SGDSW=, CNYQM3S1Y=, ILGV5YUSAC=R, MUR18M=, ZAGV5YUSAC=R, SEK2Y=, KZTON=, CHF6M=, KRW=, INRON=, UYPRIME=UYBC, MURSW=, BRLCNY=R, JPY2M=, JPYSN=, HKGV5YUSAC=R, ZARCNY4M=R, CLTPM=, VND1M=, AUDCNY18M=R, AUD3Y=, NZD18M=, SAR1M=, CADCNY3Y=R, RSGV5YUSAC=R, HICNH1YDF=, USDONFSR=X, AUDSW=, SHICNY1MD=, NACBREPO=, JPYSB6L1Y=, NAD2M=, NADSN=, MYRCNY3Y=R, QAR1Y=, VEGV5YUSAC=R, RONON=, HKDCNY6M=R, CZDISC=, PHONRP=CBPH, ZARCNYSN=R, CHF3MFSR=X, NOK18M=, ILS=, CADCNY5M=R, ZARCNY2M=R, CNH2Y=, THB3M=, PHPSW=, HKD4M=, ROGV5YUSAC=R, SERP=, AED18M=, GBP2M=, GBPSN=, JPYCNYON=R, CZK3M=, VEFTAM1W=BCDV, SGDCNY=R, HKDQM3H1Y=, KRWCNY=R, EUR3M=, MUR3Y=, AED3M=, TRY15M=, PLN1M=, SGD1M=, RUB4M=, RUGV5YUSAC=R, BHD9M=, CNY5M=, NZD9M=, CHF1MFSR=X, CNYQM3S3Y=, EURCNY=R, TWD6M=, KWD=, SEKCNH=R, JPY4M=, TRYON=, PLNDP=, CHF4M=, MNT=BOMU, KW1MREPO=, JMGV5YUSAC=R, HICNH1MDF=, LKR2Y=, DZD1WRR=BCAX, AUGV5YUSAR=R, OMR5M=, AUDCNY3M=R, MYRCNYSW=R, THBCNY=R, MYR5M=, HKDCNY15M=R, SEKON=, SEK15M=, BHSWDR=, PEMPR=, QARCNY=R, NOK=, JOD6M=, NOKSW=, CZGV5YUSAC=R, MXN15M=, CADSW=, EUR=, AEDCNY=R, MYOPRTARGET=, EURSGD=R, AED3Y=, NOK1M=, JPYCNH=R, NOINL=, QAR3Y=, EUR3Y=, RON2Y=, MYRCNY9M=R, CADCNY9M=R, RON15M=, ZAR6M=, ILS1M=, KRW1M=, THB9M=, RUB15M=, XAU=, JPY3MFSR=X, CAD3Y=, OMCDFIX1M=, SAR5M=, DKK3Y=, BHD=, FIGV5YUSAC=R, HICNH1WDF=, QARSW=, CNHQM3H6M=BRKR, SGDCNY1Y=R, AUDCNY1M=R, CNH6M=, BHDCNY=R, MOP=, ZARCNY15M=R, GBP2Y=, SHICNY3MD=, MUR1Y=, BHD3M=, LKRPWKAG=CENS, PLN1Y=, HKDQM3H3Y=, EURAB6E3Y=, CHFAB6L10Y=, TRY2Y=, HIHKD1WD=, SGD3M=, MXNON=, GBPSB6L5Y=, IDR2M=, IDRSN=, CZK9M=, USD2MFSR=X, EUR2MFSR=X, GBPSB6L7Y=, TWDISC=, SAREPO=, ZAR15M=, AUD1M=, NPR=, CHF2M=, CHF1YFSR=X, KZT2M=, CHFSN=, RUB2Y=, EGPPRML=CBEY, GBPSB6L30Y=, EURCNY9M=R, INRSN=, BGGV5YUSAC=R, INR2M=, LKRON=, JPYON=, GBPCNY4M=R, JPYINR=R, ITGV5YUSAC=R, NZD=, USDAM3L4Y=, NADON=, KZGV5YUSAC=R, INRCNYSN=R, SHICNY1YD=, TZONIBR=, MYR3M=, ZAPRIME=, AEDSW=, OMR1Y=, EURKRW=R, INRCNY2M=R, CNYQM7R4Y=, HUFCNH=R, DKKSW=, SGDCNY3M=R, JPYSB6L30Y=, ISKON=, HKDQM3H10Y=, AED=, ARGV5YUSAC=R, CAD1Y=, HKDCNYON=R, JPYSWFSR=X, RONMR=, NOK3M=, PLNSW=, GBPCNY2M=R, ILS3M=, KRW3M=, CNHQM3H4Y=BRKR, ZAR4M=, GBPSB6L10Y=, MYRCNY=R, DKK1Y=, NZD5M=, EURCNY1M=R, TRYCNH=R, LBP3WRP=BDLX, MUR9M=, GBPON=, GBBASE=, INRCNY4M=R, PHP9M=, BHD5M=, MXN2Y=, PLN3Y=, AUD=, PEGV5YUSAC=R, HKDQM3H5Y=, EURAB6E5Y=, JPYSB6L10Y=, CNY1M=, HKDINR=R, CHPRIME=, AA+CNNCD1MY=SHCV, ECBMRO=, SGD5M=, TWD2M=, VNDISC=SBVN, RUBON=, AUD3M=, CADCNYSW=R, CNYQM3S9M=, AUD18M=, COIRTARGET=, IS7DDEP=, EUR6MFSR=X, VND3M=, VNDCNY=R, CADCNY=R, GBPCNYSN=R, CZKCNY=R, NZDCNY=R, EGDISC=CBEY, SAR3M=, USDAM3L2Y=, EURSW=, /EURIBOR2WD=, OMR9M=, MYR1M=, ISDP=, DOGV5YUSAC=R, EURAB6E30Y=, GBP15M=, GBPCNH=, CHFAB6L30Y=, CLGV5YUSAC=R, CNHQM3H2Y=BRKR, CHFAB6L7Y=, SEK2M=, SEKSN=, JOD2M=]
supergwfront-biz-service.log-2021-01-11 18:33:32,346 [/// - ] INFO process.ItemNotifyTask - [300]ItemNotifyTask start!
supergwfront-biz-service.log:2021-01-11 18:33:32,740 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@df80096
supergwfront-biz-service.log:2021-01-11 18:33:32,745 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@11871cb6
supergwfront-biz-service.log:2021-01-11 18:33:32,748 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@ad59ae2
supergwfront-biz-service.log:2021-01-11 18:33:32,749 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@5c10cb43
supergwfront-biz-service.log:2021-01-11 18:33:32,750 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@5fd0cd4d
supergwfront-biz-service.log:2021-01-11 18:33:32,878 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@cffb3cd
supergwfront-biz-service.log:2021-01-11 18:33:33,028 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@2cce4137
supergwfront-biz-service.log:2021-01-11 18:33:33,062 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@2762c9e8
supergwfront-biz-service.log:2021-01-11 18:33:33,107 [/// - ] INFO reuters.ItemManager - [203--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@53e58eb0
supergwfront-biz-service.log-2021-01-11 18:33:38,035 [/// - ] INFO impl.ServiceChecker - [316]isHealthy:true
supergwfront-biz-service.log.2021-01-09-2021-01-09 11:47:19,362 [/// - ] INFO reuters.LoginClient - [202--]LoginClient: processEvent: Received Login Response
supergwfront-biz-service.log.2021-01-09-2021-01-09 11:47:19,362 [/// - ] INFO reuters.LoginClient - [202--]LoginClient: Received Login Response - MsgType.STATUS_RESP
supergwfront-biz-service.log.2021-01-09-2021-01-09 11:55:34,597 [/// - ] INFO reuters.LoginClient - [202--]LoginClient: processEvent: Received Login Response
supergwfront-biz-service.log.2021-01-09-2021-01-09 11:55:34,597 [/// - ] INFO reuters.LoginClient - [202--]LoginClient: Received Login STATUS OK Response
supergwfront-biz-service.log.2021-01-09-2021-01-09 11:55:34,597 [/// - ] INFO reuters.SimpleConsumer - [202--]Login successful
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:34,597 [/// - ] INFO reuters.ItemManager - [202--]subscribe items:[HKDCNY2M=R, MYRSW=, MYRCNY1M=R, ISK2M=, SARCNY=R, DZDDR=BCAX, NOUTL=, QAR1M=, NOK5M=, ZARCNYON=R, CZK=, HKDCNH=R, CADCNY1M=R, ILPRIME=, SAR9M=, GBPCNY6M=R, QAR=, DKDISC=, AAACNNCD1YY=SHCV, CNH2M=, CNHSN=, JPYCNYSN=R, NZD3M=, EURCNY5M=R, THBSW=, DKK9M=, CZK3Y=, HICNH3MDF=, CAD9M=, AUDCNY9M=R, ILSSW=, KRWSW=, CNY1Y=, EURVND=R, IDRON=, HKDCNYSN=R, PHP3M=, EUR9M=, EURAB6E10Y=, GBGV5YUSAC=R, GBPSB6L1Y=, DKK=, GBPSWFSR=X, HKDQM3H7Y=, ECBMRO=ECBF, TWDON=, AED9M=, KRGV5YUSAC=R, CZKSW=, DKKCNY=R, AUD5M=, BHD3Y=, JPYCNY2M=R, VND9M=, LKR2M=, BHREPO=, INR6M=, JODONDR=, CHGV5YUSAC=R, PHPCNY=R, NOGV5YUSAC=R, CAONMFR=, AAACNNCD1MY=SHCV, NOKCNY=R, JPONTARGET=, HKD2Y=, BHDSW=, SGDCNY3Y=R, AAACNNCD9MY=SHCV, CHFON=, QAR3M=, HIHKD3MD=, KZT6M=, CHFAB6L5Y=, SEK4M=, DEGV5YUSAC=R, USDAM3L8Y=, JODON=, EUR1Y=, GHPRIME=, AED1Y=, CNYSW=, JPYSB6L7Y=, CHFAB6L3Y=, EURCNYSW=R, TNTMM=, NZGV5YUSAR=R, THB1Y=, PLN=, GBPCNY2Y=R, AUDCNY=R, OMRSW=, EURCNY1Y=R, DKGV5YUSAC=R, RON6M=, PLN9M=, CNY3Y=, NZD1M=, CZK18M=, CNH4M=, UAH=, HUFBASE=, CZK1Y=, OMR=, CNY=, EURAB6E1Y=, OMRCNY=R, PLNLR=, PHP5M=, SGD9M=, BHD1M=, CNGV5YUSAC=R, SGDCNY5M=R, GBPSB6L3Y=, AA+CNNCD3MY=SHCV, INRREP=RBIA, LKR4M=, HIHKD1YD=, TRY6M=, CBTONDEPO=, PLN18M=, RWCBREPO=, INR4M=, JPY2Y=, SAR=, USDAM3L6Y=, EURCNY3M=R, USDAM3L20Y=, INRCNY6M=R, JPY1MFSR=X, EURTHB=R, QAR5M=, OMR3Y=, MYR=, EURBDT=R, CNYQM7R2Y=, MMCBR=CBMM, ALLONDR=, SEK6M=, ATGV5YUSAC=R, JPY1YFSR=X, CHF2Y=, JOGV5YUSAC=R, MXN6M=, ZARCNY6M=R, ISK6M=, KZTREFRATE=, JPYSB6L5Y=, CHFAB6L1Y=, CNYQM7R6M=, NOK9M=, JPY15M=, PAGV5YUSAC=R, CABANK=, DKUDL=, CAD5M=, LKGV5YUSAC=R, RON4M=, VND=, BEGV5YUSAC=R, HKD2M=, HKDSN=, ZARON=, GHGV5YUSAC=R, ILS9M=, KRW9M=, THB1M=, MUR3M=, GBP4M=, CNHON=, CADCNY1Y=R, CZK1M=, PLN3M=, IDGV5YUSAC=R, DKK5M=, EUR18M=, MAD=, SGD1Y=, SGDCNY9M=R, EUR5M=, HUFONRR=, AED5M=, HKDCNY2Y=R, ZMONLR=, AA+CNNCD9MY=SHCV, CHFSWFSR=X, RUB6M=, MYRCNY1Y=R, AUDCNYSW=R, CNYQM3S5Y=, AUD9M=, LKR6M=, JPY6M=, HKD15M=, GTGV5YUSAC=R, HKDCNY4M=R, SHICNY9MD=, JPYCNY2Y=R, CAD=, SARSW=, UGCBIR=, TRY4M=, MOPCNY=R, MYRCNY3M=R, VNPRIME=SBVN, NZDSW=, NZD3Y=, THPRMO=, GBP3MFSR=X, CADCNY3M=R, PLNCNY=R, USD6MFSR=X, MXGV5YUSAC=R, CNY1YD=PBOC, NGMPR=, VNDSW=, SVGV5YUSAC=R, QAR18M=, /EURIBOR2MD=, JPYCNY4M=R, GBPCNYON=R, SAR3Y=, CNYT2L=PBOC, CNYLPR1Y=, NAD6M=, CNYQM3S10Y=, OMR3M=, MYR1Y=, MZPRIME=, UAHRR=, MXN4M=, ILS1Y=, KRW1Y=, INCRR=, ZAR2Y=, HRKDISC=, AA+CNNCD1YY=SHCV, THB=, MYRCNY5M=R, EURMYR=R, KWREPO=, DKK3M=, ZARCNY2Y=R, GRGV5YUSAC=R, CAD3M=, KZBASE=NBKK, INGV5YUSAC=R, RONSN=, RON2M=, CAD18M=, NOK1Y=, AUDCNY5M=R, RUBREFRATE=, PLN5M=, JPYCNY6M=R, SGD3Y=, MUR1M=, AEREPO=, GBP1YFSR=X, CNY9M=, HIHKD1MD=, PHP1M=, GBP1MFSR=X, SHICNYSWD=, CHF15M=, AMD=, ARSCMOF7D=, GBP6M=, DKK18M=, PHP=, BHD1Y=, VND1Y=, TRYSN=, TRY2M=, SGD18M=, NZD1Y=, DZD3MRR=BCAX, MYR9M=, HUGV5YUSAC=R, CRGV5YUSAC=R, EGPONDR=CBEY, AUD1Y=, BRL=, CNYQM3S7Y=, HKDON=, AAACNNCD3MY=SHCV, INRCNYON=R, SGD=, SAR1Y=, AUDCNY3Y=R, EURONFSR=X, SGDCNYSW=R, BRTARGET=CBBR, QAR9M=, GBPINR=R, MUR=, JPYSB6L3Y=, OMR1M=, PHP1Y=, EUR1M=, DKK1M=, DKINL=, ILS5M=, CAD1M=, USDAM3L15Y=, HKD6M=, ZAR2M=, ZARSN=, NOK3Y=, CNY18M=, JODISC=, ECBDF=ECBF, PKR3DRP=SBPK, BGBASE=, CHFCNH=R, SARRP=, EURPHP=R, BDT=, ARSCMOF1D=, AED1M=, IDR6M=, RUB2M=, CZK5M=, EURAB6E7Y=, SGDCNY1M=R, AUDCNY1Y=R, CNY3M=, MXN2M=, MXNSN=, JPSPRIME=, HUFONDR=, SGDSW=, CNYQM3S1Y=, ILGV5YUSAC=R, MUR18M=, ZAGV5YUSAC=R, SEK2Y=, KZTON=, CHF6M=, KRW=, INRON=, UYPRIME=UYBC, MURSW=, BRLCNY=R, JPY2M=, JPYSN=, HKGV5YUSAC=R, ZARCNY4M=R, CLTPM=, VND1M=, AUDCNY18M=R, AUD3Y=, NZD18M=, SAR1M=, CADCNY3Y=R, RSGV5YUSAC=R, HICNH1YDF=, USDONFSR=X, AUDSW=, SHICNY1MD=, NACBREPO=, JPYSB6L1Y=, NAD2M=, NADSN=, MYRCNY3Y=R, QAR1Y=, VEGV5YUSAC=R, RONON=, HKDCNY6M=R, CZDISC=, PHONRP=CBPH, ZARCNYSN=R, CHF3MFSR=X, NOK18M=, ILS=, CADCNY5M=R, ZARCNY2M=R, CNH2Y=, THB3M=, PHPSW=, HKD4M=, ROGV5YUSAC=R, SERP=, AED18M=, GBP2M=, GBPSN=, JPYCNYON=R, CZK3M=, VEFTAM1W=BCDV, SGDCNY=R, HKDQM3H1Y=, KRWCNY=R, EUR3M=, MUR3Y=, AED3M=, TRY15M=, PLN1M=, SGD1M=, RUB4M=, RUGV5YUSAC=R, BHD9M=, CNY5M=, NZD9M=, CHF1MFSR=X, CNYQM3S3Y=, EURCNY=R, TWD6M=, KWD=, SEKCNH=R, JPY4M=, TRYON=, PLNDP=, CHF4M=, MNT=BOMU, KW1MREPO=, JMGV5YUSAC=R, HICNH1MDF=, LKR2Y=, DZD1WRR=BCAX, AUGV5YUSAR=R, OMR5M=, AUDCNY3M=R, MYRCNYSW=R, THBCNY=R, MYR5M=, HKDCNY15M=R, SEKON=, SEK15M=, BHSWDR=, PEMPR=, QARCNY=R, NOK=, JOD6M=, NOKSW=, CZGV5YUSAC=R, MXN15M=, CADSW=, EUR=, AEDCNY=R, MYOPRTARGET=, EURSGD=R, AED3Y=, NOK1M=, JPYCNH=R, NOINL=, QAR3Y=, EUR3Y=, RON2Y=, MYRCNY9M=R, CADCNY9M=R, RON15M=, ZAR6M=, ILS1M=, KRW1M=, THB9M=, RUB15M=, XAU=, JPY3MFSR=X, CAD3Y=, OMCDFIX1M=, SAR5M=, DKK3Y=, BHD=, FIGV5YUSAC=R, HICNH1WDF=, QARSW=, CNHQM3H6M=BRKR, SGDCNY1Y=R, AUDCNY1M=R, CNH6M=, BHDCNY=R, MOP=, ZARCNY15M=R, GBP2Y=, SHICNY3MD=, MUR1Y=, BHD3M=, LKRPWKAG=CENS, PLN1Y=, HKDQM3H3Y=, EURAB6E3Y=, CHFAB6L10Y=, TRY2Y=, HIHKD1WD=, SGD3M=, MXNON=, GBPSB6L5Y=, IDR2M=, IDRSN=, CZK9M=, USD2MFSR=X, EUR2MFSR=X, GBPSB6L7Y=, TWDISC=, SAREPO=, ZAR15M=, AUD1M=, NPR=, CHF2M=, CHF1YFSR=X, KZT2M=, CHFSN=, RUB2Y=, EGPPRML=CBEY, GBPSB6L30Y=, EURCNY9M=R, INRSN=, BGGV5YUSAC=R, INR2M=, LKRON=, JPYON=, GBPCNY4M=R, JPYINR=R, ITGV5YUSAC=R, NZD=, USDAM3L4Y=, NADON=, KZGV5YUSAC=R, INRCNYSN=R, SHICNY1YD=, TZONIBR=, MYR3M=, ZAPRIME=, AEDSW=, OMR1Y=, EURKRW=R, INRCNY2M=R, CNYQM7R4Y=, HUFCNH=R, DKKSW=, SGDCNY3M=R, JPYSB6L30Y=, ISKON=, HKDQM3H10Y=, AED=, ARGV5YUSAC=R, CAD1Y=, HKDCNYON=R, JPYSWFSR=X, RONMR=, NOK3M=, PLNSW=, GBPCNY2M=R, ILS3M=, KRW3M=, CNHQM3H4Y=BRKR, ZAR4M=, GBPSB6L10Y=, MYRCNY=R, DKK1Y=, NZD5M=, EURCNY1M=R, TRYCNH=R, LBP3WRP=BDLX, MUR9M=, GBPON=, GBBASE=, INRCNY4M=R, PHP9M=, BHD5M=, MXN2Y=, PLN3Y=, AUD=, PEGV5YUSAC=R, HKDQM3H5Y=, EURAB6E5Y=, JPYSB6L10Y=, CNY1M=, HKDINR=R, CHPRIME=, AA+CNNCD1MY=SHCV, ECBMRO=, SGD5M=, TWD2M=, VNDISC=SBVN, RUBON=, AUD3M=, CADCNYSW=R, CNYQM3S9M=, AUD18M=, COIRTARGET=, IS7DDEP=, EUR6MFSR=X, VND3M=, VNDCNY=R, CADCNY=R, GBPCNYSN=R, CZKCNY=R, NZDCNY=R, EGDISC=CBEY, SAR3M=, USDAM3L2Y=, EURSW=, /EURIBOR2WD=, OMR9M=, MYR1M=, ISDP=, DOGV5YUSAC=R, EURAB6E30Y=, GBP15M=, GBPCNH=, CHFAB6L30Y=, CLGV5YUSAC=R, CNHQM3H2Y=BRKR, CHFAB6L7Y=, SEK2M=, SEKSN=, JOD2M=]
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:34,611 [/// - ] INFO reuters.ItemManager - [202--]本机订阅的items:[HKDCNY2M=R, MYRSW=, MYRCNY1M=R, ISK2M=, SARCNY=R, DZDDR=BCAX, NOUTL=, QAR1M=, NOK5M=, ZARCNYON=R, CZK=, HKDCNH=R, CADCNY1M=R, ILPRIME=, SAR9M=, GBPCNY6M=R, QAR=, DKDISC=, AAACNNCD1YY=SHCV, CNH2M=, CNHSN=, JPYCNYSN=R, NZD3M=, EURCNY5M=R, THBSW=, DKK9M=, CZK3Y=, HICNH3MDF=, CAD9M=, AUDCNY9M=R, ILSSW=, KRWSW=, CNY1Y=, EURVND=R, IDRON=, HKDCNYSN=R, PHP3M=, EUR9M=, EURAB6E10Y=, GBGV5YUSAC=R, GBPSB6L1Y=, DKK=, GBPSWFSR=X, HKDQM3H7Y=, ECBMRO=ECBF, TWDON=, AED9M=, KRGV5YUSAC=R, CZKSW=, DKKCNY=R, AUD5M=, BHD3Y=, JPYCNY2M=R, VND9M=, LKR2M=, BHREPO=, INR6M=, JODONDR=, CHGV5YUSAC=R, PHPCNY=R, NOGV5YUSAC=R, CAONMFR=, AAACNNCD1MY=SHCV, NOKCNY=R, JPONTARGET=, HKD2Y=, BHDSW=, SGDCNY3Y=R, AAACNNCD9MY=SHCV, CHFON=, QAR3M=, HIHKD3MD=, KZT6M=, CHFAB6L5Y=, SEK4M=, DEGV5YUSAC=R, USDAM3L8Y=, JODON=, EUR1Y=, GHPRIME=, AED1Y=, CNYSW=, JPYSB6L7Y=, CHFAB6L3Y=, EURCNYSW=R, TNTMM=, NZGV5YUSAR=R, THB1Y=, PLN=, GBPCNY2Y=R, AUDCNY=R, OMRSW=, EURCNY1Y=R, DKGV5YUSAC=R, RON6M=, PLN9M=, CNY3Y=, NZD1M=, CZK18M=, CNH4M=, UAH=, HUFBASE=, CZK1Y=, OMR=, CNY=, EURAB6E1Y=, OMRCNY=R, PLNLR=, PHP5M=, SGD9M=, BHD1M=, CNGV5YUSAC=R, SGDCNY5M=R, GBPSB6L3Y=, AA+CNNCD3MY=SHCV, INRREP=RBIA, LKR4M=, HIHKD1YD=, TRY6M=, CBTONDEPO=, PLN18M=, RWCBREPO=, INR4M=, JPY2Y=, SAR=, USDAM3L6Y=, EURCNY3M=R, USDAM3L20Y=, INRCNY6M=R, JPY1MFSR=X, EURTHB=R, QAR5M=, OMR3Y=, MYR=, EURBDT=R, CNYQM7R2Y=, MMCBR=CBMM, ALLONDR=, SEK6M=, ATGV5YUSAC=R, JPY1YFSR=X, CHF2Y=, JOGV5YUSAC=R, MXN6M=, ZARCNY6M=R, ISK6M=, KZTREFRATE=, JPYSB6L5Y=, CHFAB6L1Y=, CNYQM7R6M=, NOK9M=, JPY15M=, PAGV5YUSAC=R, CABANK=, DKUDL=, CAD5M=, LKGV5YUSAC=R, RON4M=, VND=, BEGV5YUSAC=R, HKD2M=, HKDSN=, ZARON=, GHGV5YUSAC=R, ILS9M=, KRW9M=, THB1M=, MUR3M=, GBP4M=, CNHON=, CADCNY1Y=R, CZK1M=, PLN3M=, IDGV5YUSAC=R, DKK5M=, EUR18M=, MAD=, SGD1Y=, SGDCNY9M=R, EUR5M=, HUFONRR=, AED5M=, HKDCNY2Y=R, ZMONLR=, AA+CNNCD9MY=SHCV, CHFSWFSR=X, RUB6M=, MYRCNY1Y=R, AUDCNYSW=R, CNYQM3S5Y=, AUD9M=, LKR6M=, JPY6M=, HKD15M=, GTGV5YUSAC=R, HKDCNY4M=R, SHICNY9MD=, JPYCNY2Y=R, CAD=, SARSW=, UGCBIR=, TRY4M=, MOPCNY=R, MYRCNY3M=R, VNPRIME=SBVN, NZDSW=, NZD3Y=, THPRMO=, GBP3MFSR=X, CADCNY3M=R, PLNCNY=R, USD6MFSR=X, MXGV5YUSAC=R, CNY1YD=PBOC, NGMPR=, VNDSW=, SVGV5YUSAC=R, QAR18M=, /EURIBOR2MD=, JPYCNY4M=R, GBPCNYON=R, SAR3Y=, CNYT2L=PBOC, CNYLPR1Y=, NAD6M=, CNYQM3S10Y=, OMR3M=, MYR1Y=, MZPRIME=, UAHRR=, MXN4M=, ILS1Y=, KRW1Y=, INCRR=, ZAR2Y=, HRKDISC=, AA+CNNCD1YY=SHCV, THB=, MYRCNY5M=R, EURMYR=R, KWREPO=, DKK3M=, ZARCNY2Y=R, GRGV5YUSAC=R, CAD3M=, KZBASE=NBKK, INGV5YUSAC=R, RONSN=, RON2M=, CAD18M=, NOK1Y=, AUDCNY5M=R, RUBREFRATE=, PLN5M=, JPYCNY6M=R, SGD3Y=, MUR1M=, AEREPO=, GBP1YFSR=X, CNY9M=, HIHKD1MD=, PHP1M=, GBP1MFSR=X, SHICNYSWD=, CHF15M=, AMD=, ARSCMOF7D=, GBP6M=, DKK18M=, PHP=, BHD1Y=, VND1Y=, TRYSN=, TRY2M=, SGD18M=, NZD1Y=, DZD3MRR=BCAX, MYR9M=, HUGV5YUSAC=R, CRGV5YUSAC=R, EGPONDR=CBEY, AUD1Y=, BRL=, CNYQM3S7Y=, HKDON=, AAACNNCD3MY=SHCV, INRCNYON=R, SGD=, SAR1Y=, AUDCNY3Y=R, EURONFSR=X, SGDCNYSW=R, BRTARGET=CBBR, QAR9M=, GBPINR=R, MUR=, JPYSB6L3Y=, OMR1M=, PHP1Y=, EUR1M=, DKK1M=, DKINL=, ILS5M=, CAD1M=, USDAM3L15Y=, HKD6M=, ZAR2M=, ZARSN=, NOK3Y=, CNY18M=, JODISC=, ECBDF=ECBF, PKR3DRP=SBPK, BGBASE=, CHFCNH=R, SARRP=, EURPHP=R, BDT=, ARSCMOF1D=, AED1M=, IDR6M=, RUB2M=, CZK5M=, EURAB6E7Y=, SGDCNY1M=R, AUDCNY1Y=R, CNY3M=, MXN2M=, MXNSN=, JPSPRIME=, HUFONDR=, SGDSW=, CNYQM3S1Y=, ILGV5YUSAC=R, MUR18M=, ZAGV5YUSAC=R, SEK2Y=, KZTON=, CHF6M=, KRW=, INRON=, UYPRIME=UYBC, MURSW=, BRLCNY=R, JPY2M=, JPYSN=, HKGV5YUSAC=R, ZARCNY4M=R, CLTPM=, VND1M=, AUDCNY18M=R, AUD3Y=, NZD18M=, SAR1M=, CADCNY3Y=R, RSGV5YUSAC=R, HICNH1YDF=, USDONFSR=X, AUDSW=, SHICNY1MD=, NACBREPO=, JPYSB6L1Y=, NAD2M=, NADSN=, MYRCNY3Y=R, QAR1Y=, VEGV5YUSAC=R, RONON=, HKDCNY6M=R, CZDISC=, PHONRP=CBPH, ZARCNYSN=R, CHF3MFSR=X, NOK18M=, ILS=, CADCNY5M=R, ZARCNY2M=R, CNH2Y=, THB3M=, PHPSW=, HKD4M=, ROGV5YUSAC=R, SERP=, AED18M=, GBP2M=, GBPSN=, JPYCNYON=R, CZK3M=, VEFTAM1W=BCDV, SGDCNY=R, HKDQM3H1Y=, KRWCNY=R, EUR3M=, MUR3Y=, AED3M=, TRY15M=, PLN1M=, SGD1M=, RUB4M=, RUGV5YUSAC=R, BHD9M=, CNY5M=, NZD9M=, CHF1MFSR=X, CNYQM3S3Y=, EURCNY=R, TWD6M=, KWD=, SEKCNH=R, JPY4M=, TRYON=, PLNDP=, CHF4M=, MNT=BOMU, KW1MREPO=, JMGV5YUSAC=R, HICNH1MDF=, LKR2Y=, DZD1WRR=BCAX, AUGV5YUSAR=R, OMR5M=, AUDCNY3M=R, MYRCNYSW=R, THBCNY=R, MYR5M=, HKDCNY15M=R, SEKON=, SEK15M=, BHSWDR=, PEMPR=, QARCNY=R, NOK=, JOD6M=, NOKSW=, CZGV5YUSAC=R, MXN15M=, CADSW=, EUR=, AEDCNY=R, MYOPRTARGET=, EURSGD=R, AED3Y=, NOK1M=, JPYCNH=R, NOINL=, QAR3Y=, EUR3Y=, RON2Y=, MYRCNY9M=R, CADCNY9M=R, RON15M=, ZAR6M=, ILS1M=, KRW1M=, THB9M=, RUB15M=, XAU=, JPY3MFSR=X, CAD3Y=, OMCDFIX1M=, SAR5M=, DKK3Y=, BHD=, FIGV5YUSAC=R, HICNH1WDF=, QARSW=, CNHQM3H6M=BRKR, SGDCNY1Y=R, AUDCNY1M=R, CNH6M=, BHDCNY=R, MOP=, ZARCNY15M=R, GBP2Y=, SHICNY3MD=, MUR1Y=, BHD3M=, LKRPWKAG=CENS, PLN1Y=, HKDQM3H3Y=, EURAB6E3Y=, CHFAB6L10Y=, TRY2Y=, HIHKD1WD=, SGD3M=, MXNON=, GBPSB6L5Y=, IDR2M=, IDRSN=, CZK9M=, USD2MFSR=X, EUR2MFSR=X, GBPSB6L7Y=, TWDISC=, SAREPO=, ZAR15M=, AUD1M=, NPR=, CHF2M=, CHF1YFSR=X, KZT2M=, CHFSN=, RUB2Y=, EGPPRML=CBEY, GBPSB6L30Y=, EURCNY9M=R, INRSN=, BGGV5YUSAC=R, INR2M=, LKRON=, JPYON=, GBPCNY4M=R, JPYINR=R, ITGV5YUSAC=R, NZD=, USDAM3L4Y=, NADON=, KZGV5YUSAC=R, INRCNYSN=R, SHICNY1YD=, TZONIBR=, MYR3M=, ZAPRIME=, AEDSW=, OMR1Y=, EURKRW=R, INRCNY2M=R, CNYQM7R4Y=, HUFCNH=R, DKKSW=, SGDCNY3M=R, JPYSB6L30Y=, ISKON=, HKDQM3H10Y=, AED=, ARGV5YUSAC=R, CAD1Y=, HKDCNYON=R, JPYSWFSR=X, RONMR=, NOK3M=, PLNSW=, GBPCNY2M=R, ILS3M=, KRW3M=, CNHQM3H4Y=BRKR, ZAR4M=, GBPSB6L10Y=, MYRCNY=R, DKK1Y=, NZD5M=, EURCNY1M=R, TRYCNH=R, LBP3WRP=BDLX, MUR9M=, GBPON=, GBBASE=, INRCNY4M=R, PHP9M=, BHD5M=, MXN2Y=, PLN3Y=, AUD=, PEGV5YUSAC=R, HKDQM3H5Y=, EURAB6E5Y=, JPYSB6L10Y=, CNY1M=, HKDINR=R, CHPRIME=, AA+CNNCD1MY=SHCV, ECBMRO=, SGD5M=, TWD2M=, VNDISC=SBVN, RUBON=, AUD3M=, CADCNYSW=R, CNYQM3S9M=, AUD18M=, COIRTARGET=, IS7DDEP=, EUR6MFSR=X, VND3M=, VNDCNY=R, CADCNY=R, GBPCNYSN=R, CZKCNY=R, NZDCNY=R, EGDISC=CBEY, SAR3M=, USDAM3L2Y=, EURSW=, /EURIBOR2WD=, OMR9M=, MYR1M=, ISDP=, DOGV5YUSAC=R, EURAB6E30Y=, GBP15M=, GBPCNH=, CHFAB6L30Y=, CLGV5YUSAC=R, CNHQM3H2Y=BRKR, CHFAB6L7Y=, SEK2M=, SEKSN=, JOD2M=]
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,685 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@2453c68e
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,685 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@40506fe8
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,685 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@499e85c6
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,685 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@540281c6
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,728 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@7e2e4c83
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,728 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@ac46c2f
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,730 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@795229ee
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,730 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@69d29b3c
supergwfront-biz-service.log.2021-01-09:2021-01-09 11:55:35,850 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@3fea28cc
supergwfront-biz-service.log.2021-01-09-2021-01-09 21:34:23,908 [/// - ] INFO reuters.LoginClient - [202--]LoginClient: processEvent: Received Login Response
supergwfront-biz-service.log.2021-01-09-2021-01-09 21:34:23,908 [/// - ] INFO reuters.LoginClient - [202--]LoginClient: Received Login Response - MsgType.STATUS_RESP
supergwfront-biz-service.log.2021-01-09-2021-01-09 21:37:31,588 [/// - ] INFO reuters.LoginClient - [202--]LoginClient: processEvent: Received Login Response
supergwfront-biz-service.log.2021-01-09-2021-01-09 21:37:31,588 [/// - ] INFO reuters.LoginClient - [202--]LoginClient: Received Login STATUS OK Response
supergwfront-biz-service.log.2021-01-09-2021-01-09 21:37:31,588 [/// - ] INFO reuters.SimpleConsumer - [202--]Login successful
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:31,588 [/// - ] INFO reuters.ItemManager - [202--]subscribe items:[HKDCNY2M=R, MYRSW=, MYRCNY1M=R, ISK2M=, SARCNY=R, DZDDR=BCAX, NOUTL=, QAR1M=, NOK5M=, ZARCNYON=R, CZK=, HKDCNH=R, CADCNY1M=R, ILPRIME=, SAR9M=, GBPCNY6M=R, QAR=, DKDISC=, AAACNNCD1YY=SHCV, CNH2M=, CNHSN=, JPYCNYSN=R, NZD3M=, EURCNY5M=R, THBSW=, DKK9M=, CZK3Y=, HICNH3MDF=, CAD9M=, AUDCNY9M=R, ILSSW=, KRWSW=, CNY1Y=, EURVND=R, IDRON=, HKDCNYSN=R, PHP3M=, EUR9M=, EURAB6E10Y=, GBGV5YUSAC=R, GBPSB6L1Y=, DKK=, GBPSWFSR=X, HKDQM3H7Y=, ECBMRO=ECBF, TWDON=, AED9M=, KRGV5YUSAC=R, CZKSW=, DKKCNY=R, AUD5M=, BHD3Y=, JPYCNY2M=R, VND9M=, LKR2M=, BHREPO=, INR6M=, JODONDR=, CHGV5YUSAC=R, PHPCNY=R, NOGV5YUSAC=R, CAONMFR=, AAACNNCD1MY=SHCV, NOKCNY=R, JPONTARGET=, HKD2Y=, BHDSW=, SGDCNY3Y=R, AAACNNCD9MY=SHCV, CHFON=, QAR3M=, HIHKD3MD=, KZT6M=, CHFAB6L5Y=, SEK4M=, DEGV5YUSAC=R, USDAM3L8Y=, JODON=, EUR1Y=, GHPRIME=, AED1Y=, CNYSW=, JPYSB6L7Y=, CHFAB6L3Y=, EURCNYSW=R, TNTMM=, NZGV5YUSAR=R, THB1Y=, PLN=, GBPCNY2Y=R, AUDCNY=R, OMRSW=, EURCNY1Y=R, DKGV5YUSAC=R, RON6M=, PLN9M=, CNY3Y=, NZD1M=, CZK18M=, CNH4M=, UAH=, HUFBASE=, CZK1Y=, OMR=, CNY=, EURAB6E1Y=, OMRCNY=R, PLNLR=, PHP5M=, SGD9M=, BHD1M=, CNGV5YUSAC=R, SGDCNY5M=R, GBPSB6L3Y=, AA+CNNCD3MY=SHCV, INRREP=RBIA, LKR4M=, HIHKD1YD=, TRY6M=, CBTONDEPO=, PLN18M=, RWCBREPO=, INR4M=, JPY2Y=, SAR=, USDAM3L6Y=, EURCNY3M=R, USDAM3L20Y=, INRCNY6M=R, JPY1MFSR=X, EURTHB=R, QAR5M=, OMR3Y=, MYR=, EURBDT=R, CNYQM7R2Y=, MMCBR=CBMM, ALLONDR=, SEK6M=, ATGV5YUSAC=R, JPY1YFSR=X, CHF2Y=, JOGV5YUSAC=R, MXN6M=, ZARCNY6M=R, ISK6M=, KZTREFRATE=, JPYSB6L5Y=, CHFAB6L1Y=, CNYQM7R6M=, NOK9M=, JPY15M=, PAGV5YUSAC=R, CABANK=, DKUDL=, CAD5M=, LKGV5YUSAC=R, RON4M=, VND=, BEGV5YUSAC=R, HKD2M=, HKDSN=, ZARON=, GHGV5YUSAC=R, ILS9M=, KRW9M=, THB1M=, MUR3M=, GBP4M=, CNHON=, CADCNY1Y=R, CZK1M=, PLN3M=, IDGV5YUSAC=R, DKK5M=, EUR18M=, MAD=, SGD1Y=, SGDCNY9M=R, EUR5M=, HUFONRR=, AED5M=, HKDCNY2Y=R, ZMONLR=, AA+CNNCD9MY=SHCV, CHFSWFSR=X, RUB6M=, MYRCNY1Y=R, AUDCNYSW=R, CNYQM3S5Y=, AUD9M=, LKR6M=, JPY6M=, HKD15M=, GTGV5YUSAC=R, HKDCNY4M=R, SHICNY9MD=, JPYCNY2Y=R, CAD=, SARSW=, UGCBIR=, TRY4M=, MOPCNY=R, MYRCNY3M=R, VNPRIME=SBVN, NZDSW=, NZD3Y=, THPRMO=, GBP3MFSR=X, CADCNY3M=R, PLNCNY=R, USD6MFSR=X, MXGV5YUSAC=R, CNY1YD=PBOC, NGMPR=, VNDSW=, SVGV5YUSAC=R, QAR18M=, /EURIBOR2MD=, JPYCNY4M=R, GBPCNYON=R, SAR3Y=, CNYT2L=PBOC, CNYLPR1Y=, NAD6M=, CNYQM3S10Y=, OMR3M=, MYR1Y=, MZPRIME=, UAHRR=, MXN4M=, ILS1Y=, KRW1Y=, INCRR=, ZAR2Y=, HRKDISC=, AA+CNNCD1YY=SHCV, THB=, MYRCNY5M=R, EURMYR=R, KWREPO=, DKK3M=, ZARCNY2Y=R, GRGV5YUSAC=R, CAD3M=, KZBASE=NBKK, INGV5YUSAC=R, RONSN=, RON2M=, CAD18M=, NOK1Y=, AUDCNY5M=R, RUBREFRATE=, PLN5M=, JPYCNY6M=R, SGD3Y=, MUR1M=, AEREPO=, GBP1YFSR=X, CNY9M=, HIHKD1MD=, PHP1M=, GBP1MFSR=X, SHICNYSWD=, CHF15M=, AMD=, ARSCMOF7D=, GBP6M=, DKK18M=, PHP=, BHD1Y=, VND1Y=, TRYSN=, TRY2M=, SGD18M=, NZD1Y=, DZD3MRR=BCAX, MYR9M=, HUGV5YUSAC=R, CRGV5YUSAC=R, EGPONDR=CBEY, AUD1Y=, BRL=, CNYQM3S7Y=, HKDON=, AAACNNCD3MY=SHCV, INRCNYON=R, SGD=, SAR1Y=, AUDCNY3Y=R, EURONFSR=X, SGDCNYSW=R, BRTARGET=CBBR, QAR9M=, GBPINR=R, MUR=, JPYSB6L3Y=, OMR1M=, PHP1Y=, EUR1M=, DKK1M=, DKINL=, ILS5M=, CAD1M=, USDAM3L15Y=, HKD6M=, ZAR2M=, ZARSN=, NOK3Y=, CNY18M=, JODISC=, ECBDF=ECBF, PKR3DRP=SBPK, BGBASE=, CHFCNH=R, SARRP=, EURPHP=R, BDT=, ARSCMOF1D=, AED1M=, IDR6M=, RUB2M=, CZK5M=, EURAB6E7Y=, SGDCNY1M=R, AUDCNY1Y=R, CNY3M=, MXN2M=, MXNSN=, JPSPRIME=, HUFONDR=, SGDSW=, CNYQM3S1Y=, ILGV5YUSAC=R, MUR18M=, ZAGV5YUSAC=R, SEK2Y=, KZTON=, CHF6M=, KRW=, INRON=, UYPRIME=UYBC, MURSW=, BRLCNY=R, JPY2M=, JPYSN=, HKGV5YUSAC=R, ZARCNY4M=R, CLTPM=, VND1M=, AUDCNY18M=R, AUD3Y=, NZD18M=, SAR1M=, CADCNY3Y=R, RSGV5YUSAC=R, HICNH1YDF=, USDONFSR=X, AUDSW=, SHICNY1MD=, NACBREPO=, JPYSB6L1Y=, NAD2M=, NADSN=, MYRCNY3Y=R, QAR1Y=, VEGV5YUSAC=R, RONON=, HKDCNY6M=R, CZDISC=, PHONRP=CBPH, ZARCNYSN=R, CHF3MFSR=X, NOK18M=, ILS=, CADCNY5M=R, ZARCNY2M=R, CNH2Y=, THB3M=, PHPSW=, HKD4M=, ROGV5YUSAC=R, SERP=, AED18M=, GBP2M=, GBPSN=, JPYCNYON=R, CZK3M=, VEFTAM1W=BCDV, SGDCNY=R, HKDQM3H1Y=, KRWCNY=R, EUR3M=, MUR3Y=, AED3M=, TRY15M=, PLN1M=, SGD1M=, RUB4M=, RUGV5YUSAC=R, BHD9M=, CNY5M=, NZD9M=, CHF1MFSR=X, CNYQM3S3Y=, EURCNY=R, TWD6M=, KWD=, SEKCNH=R, JPY4M=, TRYON=, PLNDP=, CHF4M=, MNT=BOMU, KW1MREPO=, JMGV5YUSAC=R, HICNH1MDF=, LKR2Y=, DZD1WRR=BCAX, AUGV5YUSAR=R, OMR5M=, AUDCNY3M=R, MYRCNYSW=R, THBCNY=R, MYR5M=, HKDCNY15M=R, SEKON=, SEK15M=, BHSWDR=, PEMPR=, QARCNY=R, NOK=, JOD6M=, NOKSW=, CZGV5YUSAC=R, MXN15M=, CADSW=, EUR=, AEDCNY=R, MYOPRTARGET=, EURSGD=R, AED3Y=, NOK1M=, JPYCNH=R, NOINL=, QAR3Y=, EUR3Y=, RON2Y=, MYRCNY9M=R, CADCNY9M=R, RON15M=, ZAR6M=, ILS1M=, KRW1M=, THB9M=, RUB15M=, XAU=, JPY3MFSR=X, CAD3Y=, OMCDFIX1M=, SAR5M=, DKK3Y=, BHD=, FIGV5YUSAC=R, HICNH1WDF=, QARSW=, CNHQM3H6M=BRKR, SGDCNY1Y=R, AUDCNY1M=R, CNH6M=, BHDCNY=R, MOP=, ZARCNY15M=R, GBP2Y=, SHICNY3MD=, MUR1Y=, BHD3M=, LKRPWKAG=CENS, PLN1Y=, HKDQM3H3Y=, EURAB6E3Y=, CHFAB6L10Y=, TRY2Y=, HIHKD1WD=, SGD3M=, MXNON=, GBPSB6L5Y=, IDR2M=, IDRSN=, CZK9M=, USD2MFSR=X, EUR2MFSR=X, GBPSB6L7Y=, TWDISC=, SAREPO=, ZAR15M=, AUD1M=, NPR=, CHF2M=, CHF1YFSR=X, KZT2M=, CHFSN=, RUB2Y=, EGPPRML=CBEY, GBPSB6L30Y=, EURCNY9M=R, INRSN=, BGGV5YUSAC=R, INR2M=, LKRON=, JPYON=, GBPCNY4M=R, JPYINR=R, ITGV5YUSAC=R, NZD=, USDAM3L4Y=, NADON=, KZGV5YUSAC=R, INRCNYSN=R, SHICNY1YD=, TZONIBR=, MYR3M=, ZAPRIME=, AEDSW=, OMR1Y=, EURKRW=R, INRCNY2M=R, CNYQM7R4Y=, HUFCNH=R, DKKSW=, SGDCNY3M=R, JPYSB6L30Y=, ISKON=, HKDQM3H10Y=, AED=, ARGV5YUSAC=R, CAD1Y=, HKDCNYON=R, JPYSWFSR=X, RONMR=, NOK3M=, PLNSW=, GBPCNY2M=R, ILS3M=, KRW3M=, CNHQM3H4Y=BRKR, ZAR4M=, GBPSB6L10Y=, MYRCNY=R, DKK1Y=, NZD5M=, EURCNY1M=R, TRYCNH=R, LBP3WRP=BDLX, MUR9M=, GBPON=, GBBASE=, INRCNY4M=R, PHP9M=, BHD5M=, MXN2Y=, PLN3Y=, AUD=, PEGV5YUSAC=R, HKDQM3H5Y=, EURAB6E5Y=, JPYSB6L10Y=, CNY1M=, HKDINR=R, CHPRIME=, AA+CNNCD1MY=SHCV, ECBMRO=, SGD5M=, TWD2M=, VNDISC=SBVN, RUBON=, AUD3M=, CADCNYSW=R, CNYQM3S9M=, AUD18M=, COIRTARGET=, IS7DDEP=, EUR6MFSR=X, VND3M=, VNDCNY=R, CADCNY=R, GBPCNYSN=R, CZKCNY=R, NZDCNY=R, EGDISC=CBEY, SAR3M=, USDAM3L2Y=, EURSW=, /EURIBOR2WD=, OMR9M=, MYR1M=, ISDP=, DOGV5YUSAC=R, EURAB6E30Y=, GBP15M=, GBPCNH=, CHFAB6L30Y=, CLGV5YUSAC=R, CNHQM3H2Y=BRKR, CHFAB6L7Y=, SEK2M=, SEKSN=, JOD2M=]
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:31,601 [/// - ] INFO reuters.ItemManager - [202--]本机订阅的items:[HKDCNY2M=R, MYRSW=, MYRCNY1M=R, ISK2M=, SARCNY=R, DZDDR=BCAX, NOUTL=, QAR1M=, NOK5M=, ZARCNYON=R, CZK=, HKDCNH=R, CADCNY1M=R, ILPRIME=, SAR9M=, GBPCNY6M=R, QAR=, DKDISC=, AAACNNCD1YY=SHCV, CNH2M=, CNHSN=, JPYCNYSN=R, NZD3M=, EURCNY5M=R, THBSW=, DKK9M=, CZK3Y=, HICNH3MDF=, CAD9M=, AUDCNY9M=R, ILSSW=, KRWSW=, CNY1Y=, EURVND=R, IDRON=, HKDCNYSN=R, PHP3M=, EUR9M=, EURAB6E10Y=, GBGV5YUSAC=R, GBPSB6L1Y=, DKK=, GBPSWFSR=X, HKDQM3H7Y=, ECBMRO=ECBF, TWDON=, AED9M=, KRGV5YUSAC=R, CZKSW=, DKKCNY=R, AUD5M=, BHD3Y=, JPYCNY2M=R, VND9M=, LKR2M=, BHREPO=, INR6M=, JODONDR=, CHGV5YUSAC=R, PHPCNY=R, NOGV5YUSAC=R, CAONMFR=, AAACNNCD1MY=SHCV, NOKCNY=R, JPONTARGET=, HKD2Y=, BHDSW=, SGDCNY3Y=R, AAACNNCD9MY=SHCV, CHFON=, QAR3M=, HIHKD3MD=, KZT6M=, CHFAB6L5Y=, SEK4M=, DEGV5YUSAC=R, USDAM3L8Y=, JODON=, EUR1Y=, GHPRIME=, AED1Y=, CNYSW=, JPYSB6L7Y=, CHFAB6L3Y=, EURCNYSW=R, TNTMM=, NZGV5YUSAR=R, THB1Y=, PLN=, GBPCNY2Y=R, AUDCNY=R, OMRSW=, EURCNY1Y=R, DKGV5YUSAC=R, RON6M=, PLN9M=, CNY3Y=, NZD1M=, CZK18M=, CNH4M=, UAH=, HUFBASE=, CZK1Y=, OMR=, CNY=, EURAB6E1Y=, OMRCNY=R, PLNLR=, PHP5M=, SGD9M=, BHD1M=, CNGV5YUSAC=R, SGDCNY5M=R, GBPSB6L3Y=, AA+CNNCD3MY=SHCV, INRREP=RBIA, LKR4M=, HIHKD1YD=, TRY6M=, CBTONDEPO=, PLN18M=, RWCBREPO=, INR4M=, JPY2Y=, SAR=, USDAM3L6Y=, EURCNY3M=R, USDAM3L20Y=, INRCNY6M=R, JPY1MFSR=X, EURTHB=R, QAR5M=, OMR3Y=, MYR=, EURBDT=R, CNYQM7R2Y=, MMCBR=CBMM, ALLONDR=, SEK6M=, ATGV5YUSAC=R, JPY1YFSR=X, CHF2Y=, JOGV5YUSAC=R, MXN6M=, ZARCNY6M=R, ISK6M=, KZTREFRATE=, JPYSB6L5Y=, CHFAB6L1Y=, CNYQM7R6M=, NOK9M=, JPY15M=, PAGV5YUSAC=R, CABANK=, DKUDL=, CAD5M=, LKGV5YUSAC=R, RON4M=, VND=, BEGV5YUSAC=R, HKD2M=, HKDSN=, ZARON=, GHGV5YUSAC=R, ILS9M=, KRW9M=, THB1M=, MUR3M=, GBP4M=, CNHON=, CADCNY1Y=R, CZK1M=, PLN3M=, IDGV5YUSAC=R, DKK5M=, EUR18M=, MAD=, SGD1Y=, SGDCNY9M=R, EUR5M=, HUFONRR=, AED5M=, HKDCNY2Y=R, ZMONLR=, AA+CNNCD9MY=SHCV, CHFSWFSR=X, RUB6M=, MYRCNY1Y=R, AUDCNYSW=R, CNYQM3S5Y=, AUD9M=, LKR6M=, JPY6M=, HKD15M=, GTGV5YUSAC=R, HKDCNY4M=R, SHICNY9MD=, JPYCNY2Y=R, CAD=, SARSW=, UGCBIR=, TRY4M=, MOPCNY=R, MYRCNY3M=R, VNPRIME=SBVN, NZDSW=, NZD3Y=, THPRMO=, GBP3MFSR=X, CADCNY3M=R, PLNCNY=R, USD6MFSR=X, MXGV5YUSAC=R, CNY1YD=PBOC, NGMPR=, VNDSW=, SVGV5YUSAC=R, QAR18M=, /EURIBOR2MD=, JPYCNY4M=R, GBPCNYON=R, SAR3Y=, CNYT2L=PBOC, CNYLPR1Y=, NAD6M=, CNYQM3S10Y=, OMR3M=, MYR1Y=, MZPRIME=, UAHRR=, MXN4M=, ILS1Y=, KRW1Y=, INCRR=, ZAR2Y=, HRKDISC=, AA+CNNCD1YY=SHCV, THB=, MYRCNY5M=R, EURMYR=R, KWREPO=, DKK3M=, ZARCNY2Y=R, GRGV5YUSAC=R, CAD3M=, KZBASE=NBKK, INGV5YUSAC=R, RONSN=, RON2M=, CAD18M=, NOK1Y=, AUDCNY5M=R, RUBREFRATE=, PLN5M=, JPYCNY6M=R, SGD3Y=, MUR1M=, AEREPO=, GBP1YFSR=X, CNY9M=, HIHKD1MD=, PHP1M=, GBP1MFSR=X, SHICNYSWD=, CHF15M=, AMD=, ARSCMOF7D=, GBP6M=, DKK18M=, PHP=, BHD1Y=, VND1Y=, TRYSN=, TRY2M=, SGD18M=, NZD1Y=, DZD3MRR=BCAX, MYR9M=, HUGV5YUSAC=R, CRGV5YUSAC=R, EGPONDR=CBEY, AUD1Y=, BRL=, CNYQM3S7Y=, HKDON=, AAACNNCD3MY=SHCV, INRCNYON=R, SGD=, SAR1Y=, AUDCNY3Y=R, EURONFSR=X, SGDCNYSW=R, BRTARGET=CBBR, QAR9M=, GBPINR=R, MUR=, JPYSB6L3Y=, OMR1M=, PHP1Y=, EUR1M=, DKK1M=, DKINL=, ILS5M=, CAD1M=, USDAM3L15Y=, HKD6M=, ZAR2M=, ZARSN=, NOK3Y=, CNY18M=, JODISC=, ECBDF=ECBF, PKR3DRP=SBPK, BGBASE=, CHFCNH=R, SARRP=, EURPHP=R, BDT=, ARSCMOF1D=, AED1M=, IDR6M=, RUB2M=, CZK5M=, EURAB6E7Y=, SGDCNY1M=R, AUDCNY1Y=R, CNY3M=, MXN2M=, MXNSN=, JPSPRIME=, HUFONDR=, SGDSW=, CNYQM3S1Y=, ILGV5YUSAC=R, MUR18M=, ZAGV5YUSAC=R, SEK2Y=, KZTON=, CHF6M=, KRW=, INRON=, UYPRIME=UYBC, MURSW=, BRLCNY=R, JPY2M=, JPYSN=, HKGV5YUSAC=R, ZARCNY4M=R, CLTPM=, VND1M=, AUDCNY18M=R, AUD3Y=, NZD18M=, SAR1M=, CADCNY3Y=R, RSGV5YUSAC=R, HICNH1YDF=, USDONFSR=X, AUDSW=, SHICNY1MD=, NACBREPO=, JPYSB6L1Y=, NAD2M=, NADSN=, MYRCNY3Y=R, QAR1Y=, VEGV5YUSAC=R, RONON=, HKDCNY6M=R, CZDISC=, PHONRP=CBPH, ZARCNYSN=R, CHF3MFSR=X, NOK18M=, ILS=, CADCNY5M=R, ZARCNY2M=R, CNH2Y=, THB3M=, PHPSW=, HKD4M=, ROGV5YUSAC=R, SERP=, AED18M=, GBP2M=, GBPSN=, JPYCNYON=R, CZK3M=, VEFTAM1W=BCDV, SGDCNY=R, HKDQM3H1Y=, KRWCNY=R, EUR3M=, MUR3Y=, AED3M=, TRY15M=, PLN1M=, SGD1M=, RUB4M=, RUGV5YUSAC=R, BHD9M=, CNY5M=, NZD9M=, CHF1MFSR=X, CNYQM3S3Y=, EURCNY=R, TWD6M=, KWD=, SEKCNH=R, JPY4M=, TRYON=, PLNDP=, CHF4M=, MNT=BOMU, KW1MREPO=, JMGV5YUSAC=R, HICNH1MDF=, LKR2Y=, DZD1WRR=BCAX, AUGV5YUSAR=R, OMR5M=, AUDCNY3M=R, MYRCNYSW=R, THBCNY=R, MYR5M=, HKDCNY15M=R, SEKON=, SEK15M=, BHSWDR=, PEMPR=, QARCNY=R, NOK=, JOD6M=, NOKSW=, CZGV5YUSAC=R, MXN15M=, CADSW=, EUR=, AEDCNY=R, MYOPRTARGET=, EURSGD=R, AED3Y=, NOK1M=, JPYCNH=R, NOINL=, QAR3Y=, EUR3Y=, RON2Y=, MYRCNY9M=R, CADCNY9M=R, RON15M=, ZAR6M=, ILS1M=, KRW1M=, THB9M=, RUB15M=, XAU=, JPY3MFSR=X, CAD3Y=, OMCDFIX1M=, SAR5M=, DKK3Y=, BHD=, FIGV5YUSAC=R, HICNH1WDF=, QARSW=, CNHQM3H6M=BRKR, SGDCNY1Y=R, AUDCNY1M=R, CNH6M=, BHDCNY=R, MOP=, ZARCNY15M=R, GBP2Y=, SHICNY3MD=, MUR1Y=, BHD3M=, LKRPWKAG=CENS, PLN1Y=, HKDQM3H3Y=, EURAB6E3Y=, CHFAB6L10Y=, TRY2Y=, HIHKD1WD=, SGD3M=, MXNON=, GBPSB6L5Y=, IDR2M=, IDRSN=, CZK9M=, USD2MFSR=X, EUR2MFSR=X, GBPSB6L7Y=, TWDISC=, SAREPO=, ZAR15M=, AUD1M=, NPR=, CHF2M=, CHF1YFSR=X, KZT2M=, CHFSN=, RUB2Y=, EGPPRML=CBEY, GBPSB6L30Y=, EURCNY9M=R, INRSN=, BGGV5YUSAC=R, INR2M=, LKRON=, JPYON=, GBPCNY4M=R, JPYINR=R, ITGV5YUSAC=R, NZD=, USDAM3L4Y=, NADON=, KZGV5YUSAC=R, INRCNYSN=R, SHICNY1YD=, TZONIBR=, MYR3M=, ZAPRIME=, AEDSW=, OMR1Y=, EURKRW=R, INRCNY2M=R, CNYQM7R4Y=, HUFCNH=R, DKKSW=, SGDCNY3M=R, JPYSB6L30Y=, ISKON=, HKDQM3H10Y=, AED=, ARGV5YUSAC=R, CAD1Y=, HKDCNYON=R, JPYSWFSR=X, RONMR=, NOK3M=, PLNSW=, GBPCNY2M=R, ILS3M=, KRW3M=, CNHQM3H4Y=BRKR, ZAR4M=, GBPSB6L10Y=, MYRCNY=R, DKK1Y=, NZD5M=, EURCNY1M=R, TRYCNH=R, LBP3WRP=BDLX, MUR9M=, GBPON=, GBBASE=, INRCNY4M=R, PHP9M=, BHD5M=, MXN2Y=, PLN3Y=, AUD=, PEGV5YUSAC=R, HKDQM3H5Y=, EURAB6E5Y=, JPYSB6L10Y=, CNY1M=, HKDINR=R, CHPRIME=, AA+CNNCD1MY=SHCV, ECBMRO=, SGD5M=, TWD2M=, VNDISC=SBVN, RUBON=, AUD3M=, CADCNYSW=R, CNYQM3S9M=, AUD18M=, COIRTARGET=, IS7DDEP=, EUR6MFSR=X, VND3M=, VNDCNY=R, CADCNY=R, GBPCNYSN=R, CZKCNY=R, NZDCNY=R, EGDISC=CBEY, SAR3M=, USDAM3L2Y=, EURSW=, /EURIBOR2WD=, OMR9M=, MYR1M=, ISDP=, DOGV5YUSAC=R, EURAB6E30Y=, GBP15M=, GBPCNH=, CHFAB6L30Y=, CLGV5YUSAC=R, CNHQM3H2Y=BRKR, CHFAB6L7Y=, SEK2M=, SEKSN=, JOD2M=]
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:33,577 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@52df243b
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:33,577 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@4177d90c
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:33,581 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@585f6267
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:33,645 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@716bffb0
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:33,699 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@66d6f5a3
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:33,733 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@7bf73298
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:33,882 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@1640d087
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:33,891 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@378712ee
supergwfront-biz-service.log.2021-01-09:2021-01-09 21:37:34,087 [/// - ] INFO reuters.ItemManager - [202--]Receive a COMPLETION_EVENT, com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@7d6f5687
