There are different issuer rating results in get_data when we used the RIC or ISIN to search.
As the title, why cannot we use the ISIN to search issuer rating? (see attached photo, XS2252513713)
We must use the RIC to search? Have other data same problems?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonissue
Hi , 因為債券有很多報價商所以如果您用ISIN CODE 會導致不確定要用哪一個代碼抓取 , 所以建議您可以使用下面截圖的方式先拿到正確的RICS 再抓 rating 的資料
This problem impacted some company that can't find its RIC.
18k 21 12 20
Hi @jiajun
I tried this API call.
And I check the AE225251371= RIC on "Data Item Browser".
The TR.IssuerRating data is not available for this RIC.
This seems to be a content question as to why the data(TR.IssuerRating) is not available for AE225251371=
For an authoritative answer to any content questions, the best resource is the Refinitiv Content Helpdesk.
The moderators here do not have deep expertise in every type of content available through Eikon.
The Refinitiv Content Helpdesk can be reached using Contact Us capability in your Eikon application.
