When searching for historical data I came across the PE Code?
Hi @antonis
For realtime streaming data, the PE code represents a Permissionable Entity code - i.e. codes that are used to control and verify a users entitlement to a particular instrument or item of data and is used by our Data Access Control System for this purpose.
It is possible they have some other significance in the DSS data set - if so, hopefully, a DSS colleague will add some additional context/information here.
Some articles around user entitlements/permissions if you want to explore further:
An Introduction to the DACS Entitlement System for OpenDACS Developers | Refinitiv Developers
The Use Case for Decoding DACS Locks and How To Do It | Refinitiv Developers
