How to extract instruments from instrument list using REST API endpoint mentioned here API tree (https://hosted.datascopeapi.reuters.com/RestApi.Help/Context/Operation?ctx=Extractions&ent=InstrumentListItem&opn=GetAll)
23k 22 9 14
Hello @xds-support,
To extract all instruments from InstrumentList by list name, please use the two-step approach described in detail in this thread.
Does it work for you, do you run into an issue?
Alternatively, you can obtain the listId via itemId:
                {protocol}}{
                {host}}{
                {api}}Extractions/InstrumentListItems('itemId')/InstrumentList
and then do the same step two as discussed in thread
                {protocol}}{
                {host}}{
                {api}}Extractions/InstrumentLists('{
                {listId}}')/ThomsonReuters.Dss.Api.Extractions.InstrumentListGetAllInstruments
Is this what you are looking to do?
