I have a task to retrieve intraday turnover for S&P500 stocks.
Only possibility which I can see now is to retrieve data and aggregate it via codebook.
Unfortunately I am not able to retrieve data for 500 stocks (price and volume) and aggregate it (after waiting over 30 mins every time, nothing happens).
Can you help in resolving it?
Example code:
import refinitiv.dataplatform as rdp import datetime import pandas as pd rdp.open_desktop_session('DEFAULT_CODE_BOOK_APP_KEY') sp_chain = rdp.StreamingChain( session = rdp.get_default_session(), name = '0#.SPX') sp_chain.open(with_updates = False) sp_constituents = sp_chain.get_constituents() RICs = sp_constituents # the list of RICs s_date = "2020-12-22 13:00" # start date e_date = "2020-12-22 21:00" # end date Field = "ACVOL_UNS" # the field of these RICs data = pd.DataFrame() # define data is a DataFrame for aRIC in RICs: # request turnover for each RIC df = rdp.get_historical_price_summaries( universe = aRIC, start = s_date, end = e_date, interval = rdp.Intervals.ONE_HOUR, # Supported intervals: ONE_MINUTE, FIVE_MINUTES, TEN_MINUTES, THIRTY_MINUTES, ONE_HOUR fields=[Field], sessions = [ rdp.MarketSession.PRE, rdp.MarketSession.NORMAL, rdp.MarketSession.POST]) if df is None: # check if there is any error print("Error for RIC " + aRIC + ":" + str(rdp.get_last_status()['error'])) # print the error else: df[Field] = df[Field].astype(float) # convert string type to float data[aRIC] = df[Field] # create the RIC's last price column data['S&P'] = data.sum(axis=1) print(data['S&P'][-1]) data['S&P'].plot()
