EMA Tunnel Channel Disconnected
Hi Team
I've followed the tutorial for -
EMA Consumer - Posting data to Contribution Channel
using the following values on EmaConfig.xml (file taken from tutorial source code)
<Channel>
<ChannelType value="ChannelType::RSSL_ENCRYPTED"/>
<Host value="10.66.21.150"/>
<Port value="14002"/>
</Channel>
the following error comes when i try to create the OMMConsumer
I tried also without the EmaConfigFile.xml giving the parameters as string but either way it fails
Im trying to test the contributions with this tool
could you help me, please?
Thanks in advance
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apirefinitiv-realtime-sdk
@carlosrodrigo.arce
The EMA Java - RCC Contribution Example demonstrates how to directly connect to RCC server (chp02-emea2.thomsonreuters.com) to contribute the data. The configuration should be:
    <ChannelList>
        <Channel>
            <Name value="Channel_1"/>
            <!-- CompressionType is optional: defaulted to None -->
            <!-- possible values: None, ZLib, LZ4 -->
            <CompressionType value="CompressionType::None"/>
            <GuaranteedOutputBuffers value="5000"/>
            <!-- ConnectionPingTimeout is optional: defaulted to 30000 -->
            <ConnectionPingTimeout value="30000"/>
            <!-- TcpNodelay is optional: defaulted to 1 -->
            <!-- possible values: 1 (tcp_nodelay option set), 0 (tcp_nodelay not set) -->
            <TcpNodelay value="1"/>
            <Host value="chp02-emea1.thomsonreuters.com"/>
            <Port value="443"/>
        </Channel>
    </ChannelList>
The Host is chp02-emea1.thomsonreuters.com and the Port is 443.
However, from your configuration, you are using TCP port 14002 which looks that you would like to contribute data to Refinitiv Real-Time Distribution System (TREP). In this case, you can use the example 341__MarketPrice__OffStreamPost in the EMA Java package to contribute data, as mentioned in this Contributing your data to Refinitiv article.
I think you need to verify:
- You are connecting to RCC server or Refinitiv Real-Time Distribution System (TREP) to contribute the data.
- If you are connecting to Refinitiv Real-Time Distribution System (TREP), you would like to contribute data to RCC or a local contribution server, such as ATS.
