Refinitiv Real-Time SDK - Java - Contributions Channel Test Environment Service Addresses
Hi team
I've beein following the Tutorials | Refinitiv Developers and I'm trying to connect to a test environment but im unable to connect to any of the given addresses in
Giving the following error
With the nex data everything works:
Host: 10.66.21.150
Port: 14002
Service Name: ATS
RIC: USDM15D9
but i need to do contributions test so i need a test enviorment and i was give a test RIC
ETTEST01
I also want to know if there is any tutorial on how to make contribution with Java
Could you please help me
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apirefinitiv-realtime-sdk
@carlosrodrigo.arce
To connect to RCC server, you need to follow steps in the EMA Consumer - Posting data to Contribution Channel tutorial. You can download the example from the download section.
Then, you need to configure the Channel_1 to connect to the UAT server.
    <ChannelList>
        <Channel>
            <Name value="Channel_1"/>
            <ChannelType value="ChannelType::RSSL_ENCRYPTED"/>
            <!-- CompressionType is optional: defaulted to None -->
            <!-- possible values: None, ZLib, LZ4 -->
            <CompressionType value="CompressionType::None"/>
            <GuaranteedOutputBuffers value="5000"/>
            <!-- ConnectionPingTimeout is optional: defaulted to 30000 -->
            <ConnectionPingTimeout value="30000"/>
            <!-- TcpNodelay is optional: defaulted to 1 -->
            <!-- possible values: 1 (tcp_nodelay option set), 0 (tcp_nodelay not set) -->
            <TcpNodelay value="1"/>
            <Host value="contrib2-emea1.uat.platform.refinitiv.com"/>
            <Port value="443"/>
        </Channel>
    </ChannelList>
