Using Python API via MATLAB
I am using the Python API via MATLAB which works fine as long as I request only single fields:
py.eikon.set_app_key('*****');
instruments = ['LCO5000B1'];
fields= 'CF_CLOSE'; % OR fields= 'CF_CURR';
df= py.eikon.get_data(instruments,fields);
I am now struggling to get data for both fields (CF_CLOSE and CF_CURR) in a single call of get_data. What would be the correct syntax for that?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonmatlab
@Peter.Winkler3
Use py.list method of Matlab to create a Python list of fields or instruments, which can then be passed to Eikon Data APIs library for Python:
instruments = py.list({'LCO5000B1','LCO5000B2','LCO5000B3'});
fields = py.list({'CF_CLOSE','CF_CURR'});
res = py.eikon.get_data(instruments, fields);
display(res);
Thank you very much, @Alex Putkov.! It works perfectly this way!
18k 21 12 20
Hi @Peter.Winkler3
I cannot answer you on the MATLAB.
I can give you the Python example.
