Error using From method when trying to load time series from Eikon .Net SDK in Matlab
I am trying to load time series from Eikon.Net with MATLAB. I followed the instructions in the article
https://developers.refinitiv.com/article/using-eikon-net-sdk-matlab
I am able to load the last intervals like in the example successfully. However, when I'm trying to replace
timeSeriesRequestSetup.WithNumberOfPoints(10) in the SendTimeSeriesRequest function with timeSeriesRequestSetup.From, I get the following error:
No method 'From' with matching signature found for class 'ThomsonReuters.Desktop.SDK.DataAccess.TimeSeries.Impl.DataRequestSetup'.
Could you please provide and example for a time series request with specified start and end dates?
Many thanks.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythontime-seriesmatlab
@vivien.konrad
"From" and "To" methods of ITimeSeriesDataRequestSetup interface expect .NET System.DateTime type as argument.
You should be able to use
timeSeriesRequestSetup.To(System.DateTime.Now);
For more info on how to use .NET System.DateTime in Matlab see
https://www.mathworks.com/help/matlab/matlab_external/access-a-simple-net-class.html
18k 21 12 20
Hi @vivien.konrad
This is my sample code:
Thank you very much. Would you have MATLAB example as well please as it seems the input to the property is causing the issue?
My sample code which is generating the error:
