Using the Java UPA API, both the field dictionary and enumtypes files load via a file but fail when making a request using the code from the Consumer.java application (DictionaryHandler.sendRequest method). The example code uses the following string values and stream id's:
FIELD_DICTIONARY_DOWNLOAD_NAME = RWFFld FIELD_DICTIONARY_STREAM_ID = 3
ENUM_TYPE_DICTIONARY_DOWNLOAD_NAME = RWFEnum
ENUM_TYPE_DICTIONARY_STREAM_ID = 4
The assumption is that the download names are incorrect? Do these mnemonics map to a logical name associated with the underlying table?
