Client would like to get information on what does RsslServiceGeneralInfo.Capabilities message means
Client would like to know what does the following message means: "RsslServiceGeneralInfo.Capabilities"
0130 16:07:39.468629 Info: UpaSourceDirectory::processDmtSourceUpdate UPA_EQT_A-ZZZZZ
0130 16:07:39.477885 Info: RsslServiceGeneralInfo.ServiceName <ERT> -> <>
0130 16:07:39.478733 Info: RsslServiceGeneralInfo.Vendor <Thomson Reuters> -> <>
0130 16:07:39.480331 Info: RsslServiceGeneralInfo.Capabilities 5 -> 0
0130 16:07:39.480847 Info: RsslServiceGeneralInfo.Capabilities 6 -> 0
0130 16:07:39.481033 Info: RsslServiceGeneralInfo.Capabilities 7 -> 0
0130 16:07:39.481211 Info: RsslServiceGeneralInfo.Capabilities 8 -> 0
0130 16:07:39.481389 Info: RsslServiceGeneralInfo.Capabilities 9 -> 0
0130 16:07:39.481565 Info: RsslServiceGeneralInfo.Capabilities 10 -> 0
0130 16:07:39.481749 Info: RsslServiceGeneralInfo.Capabilities 11 -> 0
0130 16:07:39.481932 Info: RsslServiceGeneralInfo.Capabilities 13 -> 0
0130 16:07:39.482105 Info: RsslServiceGeneralInfo.Capabilities 18 -> 0
0130 16:07:39.482278 Info: RsslServiceGeneralInfo.Capabilities 19 -> 0
elektronelektron-sdkrrtjavaeta-apielektron-transport-api
9.5k 10 5 7
Hello @Anup.Patel
It seems to be the lists the domains which this service can provide(message types that you can request). I found the following domains according to the numbers:
  • 5 = DICTIONARY
  • 6 = MARKET_PRICE
  • 7 = MARKET_BY_ORDER
  • 8 = MARKET_BY_PRICE
  • 9= MARKET_MAKER
  • 10 = SYMBOL_LIST
  • 11 = SERVICE_PROVIDER_STATUS
  • 13 = NEWS_HEADLINE
I have not found 18 and 19, you may contact the team who takes care of the service to find out what 18 and 19 mean. For more details of the domains, please refer to ETA Java RDM Usage Guide
Note: UPA is renamed to be ETA.
11.5k 16 7 10
Hello @Anup.Patel
They are the domains value as suggest by my colleague above.
The client can find more detail in Refinitiv defined domain numbers in the following files:
  • If the client is using ETA Java: Please check <ESDK Java package>\Java\Eta\Core\src\main\java\com\thomsonreuters\upa\rdm\DomainTypes.java file
  • If the client is using ETA C++: Please check <ESDK C++>\Cpp-C\Eta\Include\Codec\rtr\rsslRDM.h file
If the services are not define in those files (such as 18 and 19), you need to contact the team who the server/service to verify on the server side.
