I use ScheduleExtractNow functionality to retrieve data immediately. When my query takes to long (more than 30 s), I get response with status code 202. According to the documentation I grab the "Location" field from the response's header and issue GET against this location to poll the report to determine when it has completed. Unfortunately, when I send the request based on this location I receive 501 status code. I figured out that location field gives me the wrong address. The correct one, according to REST API Tree, should look like this:
.../Extractions/Schedules({id})/ThomsonReuters.Dss.Api.Extractions.ScheduleExtractNowResult(Extraction='id_report_ext')
but I actually get sth like this
.../Extractions/Schedules({id})/DataScope.Select.Api.Extractions.ScheduleExtractNowResult(Extraction='id_report_ext')
from the location field. This is a bug, am I right?
