Can't connect to remote server
Hello
I'm getting an exception "Can't connect to the remote server"
when trying to access DataScope Select Rest API
I tried postman and it's working okay, but when I try it from our C# project I'm getting this exception
the url:
https://hosted.datascopeapi.reuters.com/RestApi/v1/Authentication/RequestToken
Exception:
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.177.23:8080
stack trace:
   at ThomsonReuters.Dss.Api.Core.HttpOData.Http.HttpClientExceptionDecorator.<HandleExceptions>d__11.MoveNext() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\HttpOData\Http\HttpClientExceptionDecorator.cs:line 177
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at ThomsonReuters.Dss.Api.Core.HttpOData.Http.HttpClientExceptionDecorator.<HandleExceptions>d__11.MoveNext() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\HttpOData\Http\HttpClientExceptionDecorator.cs:line 198
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at ThomsonReuters.Dss.Api.Core.HttpOData.Http.HttpAsyncJobStrategy.<InvokeAsync>d__0.MoveNext() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\HttpOData\Http\HttpAsyncJobStrategy.cs:line 33
   at ThomsonReuters.Dss.Api.Core.HttpOData.HttpODataClient.<InternalExecuteAsync>d__87.MoveNext() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\HttpOData\HttpODataClient.cs:line 542
   at ThomsonReuters.Dss.Api.Core.HttpOData.HttpODataClient.<ExecuteAsync>d__7d`1.MoveNext() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\HttpOData\HttpODataClient.cs:line 515
   at ThomsonReuters.Dss.Api.Core.OperationsBaseForHttpODataClient.<CallOnHttpODataClient>d__10b`1.MoveNext() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\OperationsBaseForHttpODataClient.cs:line 0
   at ThomsonReuters.Dss.Api.Core.Helper.<ReAuthenticateIfNecessaryAsync>d__6`1.MoveNext() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\Helper.cs:line 0
   at ThomsonReuters.Dss.Api.Core.OperationsBaseForHttpODataClient.<ExecuteAsync>d__a0`1.MoveNext() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\OperationsBaseForHttpODataClient.cs:line 0
   at ThomsonReuters.Dss.Core.RestApi.Threading.Tasks.AsyncHelper.RunSync[TResult](Func`1 func) in d:\BuildAgent\work\5085137dd0574126\src\Core\Threading\Tasks\AsyncHelper.cs:line 25
   at ThomsonReuters.Dss.Api.Core.OperationsBase.InvokeSynchronously[T](Func`1 action) in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\OperationsBase.cs:line 397
   at ThomsonReuters.Dss.Api.Core.OperationsBase.Execute[T](DssDataServiceContext context, Uri uri, String httpMethod, Boolean isSingle, OperationParameter[] parameters, String queryOptions) in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\OperationsBase.cs:line 238
   at ThomsonReuters.Dss.Api.DssDataServiceContext.<>c__DisplayClass12`1.<Execute>b__11() in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\DssDataServiceContext.cs:line 303
   at ThomsonReuters.Dss.Api.Core.Helper.ReAuthenticateIfNecessary[T](IDssDataServiceContext context, Func`1 method) in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\Helper.cs:line 40
   at ThomsonReuters.Dss.Api.DssDataServiceContext.Execute[TElement](Uri requestUri, String httpMethod, Boolean singleResult, OperationParameter[] operationParameters, String queryOptions) in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\DssDataServiceContext.cs:line 301
   at ThomsonReuters.Dss.Api.Authentication.AuthenticationContext.RequestToken(Credentials credentials) in d:\BuildAgent\work\5085137dd0574126\src\Api\RestApi.Client\AuthenticationClientApi.generated.cs:line 117
   at ThomsonReuters.Dss.Api.DssDataServiceContext.Authenticate(Uri serviceRoot, NetworkCredential networkCredential) in d:\BuildAgent\work\5085137dd0574126\src\ServiceLayer\ServiceLayer.Client\Core\DssDataServiceContext.cs:line 158
dss-rest-apidatascope-selectdsserror
13.7k 26 8 12
@h.aburajouh, from the exception message it looks like you are trying to connect through a proxy. See this trail that discusses the issue, it should help.
Yes it was a proxy problem
thanks
