Elektron SDK for ERT in Cloud
Hi, when I ran "example113__MarketPrice__SessionManagement", the following error was displayed.
Please tell me the possible causes.
The details of the error are as follows.
loggerMsg
Severity: Error
Text: Failed to add RsslChannel(s) to RsslReactor. Channel name(s)
Instance Name Consumer_3_1
RsslReactor @6e171cd7
RsslChannel null
Error Id -1
Internal sysError 0
Error Location RestReactor.submitAuthRequestBlocking
Error Text failed to submit authorization request, exception = Connect to api.refinitiv.com:443 [api.refinitiv.com/52.77.7.84, api.refinitiv.com/13.251.240.49, api.refinitiv.com/18.136.231.162] failed: Connection timed out: connect
loggerMsgEnd
11.5k 16 7 10
Hello @yuichiro.saito
The "java.net.connectException: Connection timed out: connect" exception mean the application did not get a response from server in time. It is most likely to be a network issue. I strongly suggest you contact your network team to verify if api.refinitiv.com:443 is blocked on your site or not.
The other ways to verify are using Postman example (RDP-> Authenticate -> Get Access Token, download here) or the curl command to connect to the endpoint directly:
Example curl command:
curl --location --request POST 'https://api.refinitiv.com/auth/oauth2/v1/token' \
--header 'Content-Type: application/x-www-form-urlencoded' \
--data-urlencode 'username=<myUsername>' \
--data-urlencode 'password=<myPassword>' \
--data-urlencode 'grant_type=password' \
--data-urlencode 'scope=trapi' \
--data-urlencode 'takeExclusiveSignOnControl=true' \
--data-urlencode 'client_id=<myClientId>'
Hello @wasin.waeosri
Thank you for your response.
When I executed the "curl" command, the following error was displayed.
curl: (7) Failed to connect to api.refinitiv.com port 443: Timed out
curl: (6) Could not resolve host: application
Based on the curl result, it seems your machine cannot access api.refinitiv.com API endpoint port 443. I suggest you contact your network team to verify on your side.
11.5k 16 7 10
Which version of EMA Java that you are using? I have tested with EMA Java version 3.5.1 (RTSDK 1.5.1) and Java SDK 8, the example113 works fine.
Please note that the EMA Java API needs to send authentication message to RDP Auth Server https://api.refinitiv.com/auth/oauth2/v1/token endpoint first. Does you network block access to api.refinitiv.com endpoint?
I'm running in a similar environment.
(EMA Java version 3.5.1 (RTSDK 1.5.1) and Java SDK 8)
When I accessed "api.refinitiv.com" from my PC, the login screen was displayed and it was not blocked.
When I run it using Gradle(runconsumer113), I get the following error:
