When connecting to DSWS; I get 'SSLError(SSLError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:852)' Error
Hi All,
I am trying to pull data from DSWS using python. However even after providing username, password, and proxy details, I'm receiving this error. In the documentation it is mentioned that I should be doing something like this:
Please find the SSL certificate path on your local machine and provide the same in the code as shown below:
import DatastreamDSWS as dsws
ds = dsws.Datastream(username='XXXXXXX', password='XXXXXXX', sslCer='path\certfile', proxy='XXXXXXX:XXX')
However, I am unbale to figure out which certificate is needed exactly for the sslCer parameter and how to find its path on my local machine? Pls help, thank you
datastream-apidsws-api
Hi, pls help as I've hit a roadblock here
@akshay.kaushal
The DataStreamWS URL is https://product.datastream.com. I have checked this URL with https://www.sslshopper.com/. It uses a COMODO certificate so it should be this file: http://crt.comodoca.com/COMODORSAOrganizationValidationSecureServerCA.crt.
However, if you use a proxy server, you need to contact your IT support team for the certificate file of the proxy server.
The certificate file path depends on the operating system. You need to refer to the operating system documentation for the certificate file path. I found answers on this website.
Hi @jirapongse.phuriphanvichai, thank you so much for your reply. I will ask the IT for the same.
