I am trying to contribute to a RIC that has the PERM_CODE FID. I am creating a Post message with 2 Fields encoded, 1 fr the permission FID with the code and 2nd for the price FID i want to update. However I keep getting this error
Message ID 4.0 received NACK : A29: Post message did not contain permission data.
I am sure my postMsg with multiple FID update works because I tried it on another RIC which does not require the permission code.
Any pointers here will be very helpful!
Thanks.
OMMEncoder encoder = publisherPool.acquireEncoder(); OMMMsg ricPubMsg = publisherPool.acquireMsg(); ricPubMsg.setMsgType(OMMMsg.MsgType.POST); ricPubMsg.setId(id); ricPubMsg.setMsgModelType(RDMMsgTypes.MARKET_PRICE); ricPubMsg.setPriority((byte) 1, 1); // A single-part post message that needs init, complete and ack indications. int indicationFlags = OMMMsg.Indication.POST_COMPLETE | OMMMsg.Indication.POST_INIT | OMMMsg.Indication.NEED_ACK; ricPubMsg.setIndicationFlags(indicationFlags); ricPubMsg.setAttribInfo(key.serviceName, key.ric, RDMInstrument.NameType.RIC); encoder.initialize(OMMTypes.MSG, 1000); encoder.encodeMsgInit(ricPubMsg, OMMTypes.NO_DATA, OMMTypes.FIELD_LIST); encoder.encodeFieldListInit(OMMFieldList.HAS_STANDARD_DATA | OMMFieldList.HAS_INFO, (short) 1, (short) 0, (short) 2); int count = 0; for(RField fid : key.fids) { FidDef fidDef = dictionary.getFidDef(fid.id); short fidType = fidDef.getOMMType(); encoder.encodeFieldEntryInit(fidDef.getFieldId(), fidType); String rep; Object value = values.get(count); if(value == null){ rep = ""; }else{ Class<?> valueClass = value.getClass(); if (fidType == OMMTypes.UINT) { encoder.encodeUInt(Long.parseLong(value.toString())); } else { if(Float.class.equals(valueClass) || Double.class.equals(valueClass)){ rep = DECIMAL_FORMAT.format(value); }else{ rep = value.toString(); } encoder.encodeString(rep, fidType); } } count++; } encoder.encodeAggregateComplete(); OMMMsg pubMsg = (OMMMsg) encoder.getEncodedObject();
