Post Id must exist for multiple part post message
Hi Everyone,
I am getting this error when I post using an OMM Consumer:
I am not sure I understand, I create the message like so:
private OMMMsg createMsg(final Map<String, String> data) {
    encoder.initialize(OMMTypes.MSG, 1000);
    encoder.encodeMsgInit(marketDataItemCont, OMMTypes.NO_DATA, OMMTypes.FIELD_LIST);
    encoder.encodeFieldListInit(OMMFieldList.HAS_STANDARD_DATA, (short) 0, (short) 1, (short) 0);
    for (Entry<String, String> d : data.entrySet()) {
      final Integer id = RfaUtils.getFieldId(d.getKey());
      final String value = d.getValue();
      encoder.encodeFieldEntryInit(id.shortValue(), OMMTypes.ASCII_STRING);
      encoder.encodeString(value, OMMTypes.ASCII_STRING);
    encoder.encodeAggregateComplete();
    return (OMMMsg) encoder.getEncodedObject();
public int postMsg(final Map<String, String> data) {
      marketDataItem.clear();
      marketDataItem.setMsgModelType(RDMMsgTypes.MARKET_PRICE);
      marketDataItem.setMsgType(OMMMsg.MsgType.POST);
      marketDataItem.setAttribInfo(serviceName, itemName, RDMInstrument.NameType.RIC);
      marketDataItem.setIndicationFlags(OMMMsg.Indication.NEED_ACK);
      ommPostHandleItemCmd.setMsg(createMsg(data));
      ommPostHandleItemCmd.setHandle(contribHandle);
      return ommConsumer.submit(ommPostHandleItemCmd, contribHandle);
Does someone see something wrong?
Thanks,
Gabriel
treprfarfa-apiOMMcontributionspost
Hi @glr
Are you setting a PostID for each post msg anywhere in your code e.g.
marketDataItem.setId(iPostId);
Assuming that marketDataItem is your OmmMsg.
Post ID is the unique identifier (that distinguishes different post messages). Each part in a multi-part post message must use the same postId value.
postId allows for values ranging from 0 to 4,294,967,295.
Regards,
Umer
