"Failed to convert to UTF8 in RmtesBufferImpl :: toString (). Reason: RSSL_RET_FAILURE”
When I receive an update in EMA C ++, I get the following message: Please tell me what to do.
"Failed to convert to UTF8 in RmtesBufferImpl :: toString (). Reason: RSSL_RET_FAILURE"
The requested RIC is as follows.
OS/ACT13
OS/ACT36
OS/ACT37
OS/ACT39
OS/ACT41
OS/ACT42
OS/ACT43
OS/ACT44
OS/ACT45
OS/ACT88
OS/ACT89
7.6k 15 6 9
@tatmatsu
The RIC provides page data and each row uses RMTES data type.
You need to check the type of fieldEntry and then get string using fe.getRmtes().toString()
switch ( fe.getLoadType() )
  case DataType::RmtesEnum:
    cout << fe.getRmtes().toString() << endl;
                break;
Also, some RIC may use RMTES partial update in the update message so please refer to information from the following post to decode the data.
https://community.developers.refinitiv.com/questions/58724/how-to-check-whether-rmtes-string-contains-partial.html
