Corporate actions using c#
Can I achieve using C# the equivalent of the below python api call
ek.get_data(['BHP.AX'], ['TR.AdjmtFactorAdjustmentDate', 'TR.AdjmtFactorAdjustmentFactor'], {'EDate': '2018-09-29', 'SDate': '1980-01-01'}, debug = True, raw_output=True)
Kind regards
Dean
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonc#
18k 21 12 20
An alternative to the suggestion from @chavalit.jintamalit is the following library available from NuGet, which provides very similar interface to the Eikon Data APIs Python library.
https://www.nuget.org/packages/EikonDataAPI/
Thanks for your response. I couldn't use the python library as it doesn't work under Metastock Xenith variant of Eikon so DEX2 it is.
Thanks, I have used this successfully now.
