How to listen to Economic Monitor real time stream with C#
I am trying to follow the tutorial for real time streams using Eikon .NET with C#. It shows an example for getting the bid or ask for a currency but I am not sure how to get updates from the economic monitor.
I have tried the following:
singleSubscription = realtime.Subscribe("JPPMIS=ECI", "Actual", DataReceived);
and
singleSubscription = realtime.Subscribe("JPPMIS=", "ECI", DataReceived);
but neither worked.
Any ideas?
Thanks.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonrefinitiv-realtimec#economic-data
The IRealtimeService.Subscribe method is used to retrieve real-time fields as displayed on the Eikon Quote application. Actual is not a valid real-time field. Please try the ECON_ACT field instead.
realtime.Subscribe("JPPMIS=ECI", "ECON_ACT", (field) =>
    Console.WriteLine("Field: {0}, value: {1}", field.Field, field.ToString());
The output is:
Field: ECON_ACT, value: +50.2
To list all available real-time fields, please use Display All Fields on the Eikon Quote application.
This is very helpful. Thank you very much for the screenshot.
