How to override fields for On Demand Extraction?
We have to calculate the warrants ratio using Asset Ratio Against and Asset Ratio For in dss terms and conditions template. However, the default rounding is nearest integer. We want to override these two fields to add more decimals in On Demand Extraction so that precise warrant ratio can be calculated. However, i checked previous cases and seems this functions are not yet supported. May I know if there is any update now? Or is there any other methods in on demand extraction so that I can get precise warrant ratio ?
E.g. PMAS_tl.KL, we expect the asset ratio for 3.3333 and asset ratio against as 1. We want to calculate the warrants ratio as 1/3.3333 = 0.30003
@rickyc
From my checking, DecimalPlaces property is not available via On Demand extraction. It only accepts strings for the ContentFieldNames.
The solution, for now, is using the immediate extraction with the instrument and report template. Please refer to this question.
However, you may directly contact the DSS support team via MyRefinitiv to confirm this.
anyone has reply ?
