EMA - How do I use batch reissue and close
SupportBatchRequests is set to 7 on ADS, according to EMA Java RDM Usage Guide it supports batch reissue. I'd like to pause/resume a number of instruments using batch reissue, how do I do it? I assume batch reissue also uses OmmConsumer.reissue(ReqMsg, long) , how do I pass in multiple handles to batch reissue?
Additionally, what is batch close? Is it batch unregister? If so, how do I use it? The examples in the SDK only shows how a batch request is made which doesn't have the handle argument.
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apijavabatch
Hi @ahmire.kailer
According to the API_ConceptsGuide.pdf which comes with ElektronSDK Java1.5 and Elektron SDK C 1.5, EMA does not support Batch Re-issue and Close
You would have to use ETA or re-issue / close the items individually.
You can close all items by unregistering the MMT_LOGIN handle which will close all open item streams - however, this will mean you are also logged out - which I expect is not what you are after.
The RDMUsageGuide explains what the various elements in the Login response mean. The SupportBatchRequests indicates what the Provider you are connecting to supports - not what the API supports.
