Looking in the EMA C++ documentation, I could not find any mention of closing a streaming batch of items. While I'm aware you can close a specific item, I could not find any guidelines around closing a batch, so I assumed it was similar to closing a single streaming item.
However, I was wrong.
When you perform a registerClient() on a consumer for a single item, you can use the returned handle to unregister that item, i.e.
UInt64 handle = ommConsumer.registerClient(<single item>); ... ommConsumer.unregister(handle);
However, despite being intuitive, you can't do this with a batch. When you do, it will throw an exception that contains the error text:
"Invalid attempt to close batch stream. Instance name='Consumer_1_1"
The error message doesn't say you can't close a batch stream, but rather it was an invalid attempt. Fair enough. What is the valid way to do this? Can someone point me to where this is documented?
